Oil Drip
Old Feb 11, 2013 | 01:35 PM
Dodgeboy77's Avatar
Dodgeboy77
Default Oil Drip
I have an oil drip, it drips down over the oil filter. i thought it was the filter and changed the oil and filter, but it still drips. anyone have this problem? thanks
Old Feb 11, 2013 | 02:56 PM
Wes Garrett's Avatar
Wes Garrett
my guess is a valve cover gasket, or maybe a head gasket.
Old Feb 11, 2013 | 04:25 PM
5hundo's Avatar
5hundo
Here's an old trick that aviation mechnics use. You can use it for all liquid leaks, not just oil:
Clean the suspect area with a steam cleaner, or degreser. Allow time for the parts to dry. Apply a liberal quantity of talc powder around the suspect area. Drive the vehicle for an hour, or two. Immediatly after driving, look for "lines" of wet spots in the talc powder. Treat those lines like "arrows"; they will point you directly to the source of your leak. If the "line" ends, try again, but move apply more talc powder beyond where the line ended. Works like a charm!
Old Feb 11, 2013 | 07:20 PM
Dodgeboy77's Avatar
Dodgeboy77
i am on vacation, i don't have talc to try. the leak is right from the top of the filter, not a head or valve cover
Old Feb 11, 2013 | 07:42 PM
mmguy18's Avatar
mmguy18
Not sure about your motor. But were the filter screws in may be just a adapter plate. In that case there be a gasket behind it.
Old Feb 11, 2013 | 07:52 PM
Dodgeboy77's Avatar
Dodgeboy77
ya maybe. i couldn't see anything with the filter off so i thought it was the filter. i thought someone else may have had this happen before.
Old Feb 11, 2013 | 08:03 PM
Tom A's Avatar
Tom A
Section Moderator
I'm not familiar with your engine, but is there an oil pressure switch above your filter? Those have been known to leak.
Old Feb 11, 2013 | 08:33 PM
Dodgeboy77's Avatar
Dodgeboy77
ya there is. you can't see if it is leaking with the filter on.
Old Feb 11, 2013 | 10:03 PM
Tom A's Avatar
Tom A
Section Moderator
Maybe you can clean it up, run it for a few minutes, then see if it has oil coming out of it?
Old Feb 11, 2013 | 10:51 PM
Dodgeboy77's Avatar
Dodgeboy77
i have cleaned it up a few times, i only get a drip coming off the filter. i tied a rag on top of the filter and it stayed dry till the rag soaked.
