01 3.9 fuel efficiency
Old Feb 14, 2013 | 07:07 PM
froggyman222's Avatar
froggyman222
Default 01 3.9 fuel efficiency
So I get 150 to 200 miles per tank and when I went to go calculate my mpg it said I only got 8 how I got it was how many miles I went divided by how much the tank holds
Old Feb 14, 2013 | 09:21 PM
MadisonDakota's Avatar
MadisonDakota
You've got something majorly wrong. Any check engine lights?
Old Feb 14, 2013 | 10:08 PM
00DakDan's Avatar
00DakDan
Section Moderator
That's not how you calculate your mileage.
Start with a full tank, drive until you refill. Then take the mileage and divide by what you put into the tank, not how much it holds.
Old Feb 14, 2013 | 10:20 PM
magnethead's Avatar
magnethead
ignoring his erroneous math, 150-200 per tank is pitiful.. I get the better part of 275-300 even with my heavy foot, averaging 12-14 calculated correctly.
Old Feb 14, 2013 | 10:22 PM
dodgeramguy85's Avatar
dodgeramguy85
Still if he is only getting 150-200 a tank. I was getting at least 250-300 on a tank
Old Feb 15, 2013 | 12:02 AM
kyle3194's Avatar
kyle3194
Yea my 3.9 gets around 250-300 15mpg basically
Old Feb 15, 2013 | 01:26 AM
Hahns5.2's Avatar
Hahns5.2
Nor does basing your mileage off of "distance per tank" mean anything unless you're literally running it out of gas.
Gas gauges do not give you a good idea of how much is left in the tank, furthermore, when the fuel light comes on in a Dodge, there's typically ~5 gallons left.
Old Feb 15, 2013 | 11:16 AM
froggyman222
i dont have any thing wrong no lights no nothing it dosent make any sense but i can go like 2 weeks per tank and i fill it up with about 18 gal everytime
Old Feb 15, 2013 | 11:22 AM
froggyman222
i also use the trip meeter and i clear it everytime i fill up
Old Feb 15, 2013 | 11:45 AM
stealth13's Avatar
stealth13
Full your tank all the way . Let's say you drive 100 miles, then fill up all the way and it takes 10 gallons. You then got 10mpg
