Differential Fluid Change?
Old Feb 15, 2013 | 07:29 PM
MadisonDakota's Avatar
MadisonDakota
Default Differential Fluid Change?
Easy as pie.
3 quarts of Mobil 1 75w90 LS, 32.97 @ Advance Auto + coupon code A124 for a total of 22.97+ tax.
1 tube of RTV, you're favorite flavor. Some say to only use the stuff formulated for gear oil, I didn't.
Remove 12/10 bolts off the diff cover. (You have a big *** drain pan under there, right?)
Clean up the old RTV off the mating surfaces, and clean them with brake cleaner.
Follow the RTVs directions for re-install, fill with 2.1 quarts of oil. (mix the remaining oil with a Vodka and Seafoam for a delicious late night drink.)
Old Feb 15, 2013 | 08:08 PM
moe7404's Avatar
moe7404
i dont like RTV. try permatex no 2, just my ideas. oh yea iam totally OLD SCHOOL.
Old Feb 15, 2013 | 09:37 PM
joe002's Avatar
joe002
What's wrong with spraying brake cleaner on the housing?
Old Feb 15, 2013 | 10:15 PM
MadisonDakota
I read that you don't want to get any on the gears. I don't know if it's true or not, but I didn't want to risk it.
Old Feb 15, 2013 | 10:34 PM
joe002's Avatar
joe002
OK, I hadn't read that. I usually spray the brake cleaner all over everything inside to help clean out metal filings, etc.
Old Feb 15, 2013 | 11:08 PM
98DAKAZ's Avatar
98DAKAZ
Brake cleaner will not hurt anything I used it no problems just let it open air dry out for half an hour to be sure it’s all evaporated.
To get the oil mixed into the bearings I drove it very slowly around the block a few times.
Old Feb 15, 2013 | 11:13 PM
joe002's Avatar
joe002
Shiny.
Old Feb 16, 2013 | 01:28 PM
Tom A's Avatar
Tom A
Section Moderator
I must be even OLDER SCHOOL because I prefer to use a gasket.
Old Feb 16, 2013 | 10:26 PM
mmguy18's Avatar
mmguy18
I prefer a gasket. Brake cleaner is a good degreaser shouldn't hurt anything. Just let it dry good and wipe it up good.
Old Feb 16, 2013 | 10:50 PM
joe002's Avatar
joe002
Did you seal the filler plug with something, or just pop it in when you were done?
