Squeaking
Old Mar 11, 2013 | 05:32 PM
jake7's Avatar
jake7
Default Squeaking
Hi all. I need some help narrowing down a bunch of noise (squeaking) coming from under the truck. It squeaks when i turn the stearing wheel at low speeds (through parking lots and such). It also squeaks when going over any sort of bumps...shocks maybe? It only has 40k miles on it. It's a 2003.
I've tried the search and will continue searching in case i looked over something but any help is appreciated
Old Mar 13, 2013 | 12:37 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-forum.
Old Mar 13, 2013 | 12:41 AM
01SilverCC's Avatar
01SilverCC
First thing to check would be the stabilizer bar end links.
Jimmy
Old Mar 13, 2013 | 09:44 AM
Robbadodge's Avatar
Robbadodge
Honestly, I thought it was normal... Mine has squeaked since I purchased it in '05.
I'd like to know where I can lube to get rid of it, but I'm not bothered, yet.
Old Mar 13, 2013 | 10:24 AM
BCdakotaboy's Avatar
BCdakotaboy
Sway bar bushings, mine did the same noise. Replaced them with polyurethane bushings and no squeak since.
Old Mar 13, 2013 | 11:20 AM
00DakDan's Avatar
00DakDan
Section Moderator
I had "squeaky" shock. Replace it, gone.
Old Mar 13, 2013 | 12:39 PM
Mopar2108's Avatar
Mopar2108
Also try looking into the bushings on the A arm. I know mine is a few years older but i know they give off alot of noise.
Old Mar 13, 2013 | 05:29 PM
TheePlaymaker's Avatar
TheePlaymaker
I agree with BCDakotaboy on the sway bar bushings. You guys should try this thread and see if it sounds similar and what to look for!! I had the same symptoms you described and I did the poly ones on mine, fixed it then they got squeaky again, so I just had to take them off and grease them some more. I think it was from all the long trips on the salty winter roads when I was going to and from school a few years ago, hasn't come back since I greased them the second time.
https://dodgeforum.com/forum/diy-do-...geeteeohh.html
Old Mar 14, 2013 | 12:43 AM
joe002's Avatar
joe002
To see where the squeak is/are coming from you can try spraying your various bushings (one at a time). When the squeaks stop you found the culprit(s). Mine was the sway bar bushings too.
