This may be a stupid question...
Old Apr 17, 2013 | 09:53 AM
Stuff105's Avatar
Stuff105
Default This may be a stupid question...
What is the piece of the rear drive shaft that goes into the transfer case that slips over the output shaft ? I am drawing a blank on the actually name and mine has some deep grooves in it and i want to replace it .It has that large circular piece on it as well. Thanks guys
Old Apr 17, 2013 | 10:09 AM
sl2racer's Avatar
sl2racer
are you talking about the yoke?
Old Apr 17, 2013 | 10:12 AM
Stuff105's Avatar
Stuff105
Yes that's what i was thinking! haha Anyone know anywhere to find one?
Old Apr 17, 2013 | 12:18 PM
DakCC4x4's Avatar
DakCC4x4
Eggland.....jk. You could try www.rockauto.com
Old Apr 17, 2013 | 02:24 PM
Stuff105's Avatar
Stuff105
couldn't find it.... Man this sucks lol
Old Apr 17, 2013 | 03:12 PM
00DakDan's Avatar
00DakDan
Section Moderator
Boneyard or dealer
Old Apr 17, 2013 | 09:04 PM
Stuff105's Avatar
Stuff105
discontinued by dodge... story my life on this truck
Old Apr 17, 2013 | 09:28 PM
magnethead's Avatar
magnethead
I was gonna say, probably sold as part of the driveshaft assembly.
Any driveshaft shop should be able to lathe it out or replace it.
Old Apr 17, 2013 | 09:36 PM
00DakDan's Avatar
00DakDan
Section Moderator
It happens. Most manufacturers only support vehicles for about 10 years. Up until a few years ago it was very rare to run anything past that. Most were dying by about 5-6 years.
Don't rule out a boneyard. They can keep your ride alive for a while, especially on something such as a yoke that normally isn't damaged.
Old Apr 17, 2013 | 10:54 PM
Tom A's Avatar
Tom A
Section Moderator
As I recently learned, the slip yoke that goes into the back of the transfer case is NOT a standard size. Every other 27-spline yoke is 1.5" OD and ours (or at least mine) measures something like 1.556" OD. Needless to say, if you put a brand new Tom Woods 1350-series driveshaft on the rear with a standard 27-spline slip yoke so that you won't have to run a conversion u-joint on your Chevy rear end, it will leak profusely. Don't ask me how I know.
So now, instead of using a conversion joint at the rear end, I'm using it at the transfer case end with the stock slip yoke. Yay.
