Installing a Tach
Old May 9, 2013 | 11:55 PM
Klokworx's Avatar
Klokworx
Default Installing a Tach
can someone give me a hint as to where the tach wire is on the 98 2.5?
Old May 10, 2013 | 12:08 AM
00DakDan's Avatar
00DakDan
Section Moderator
Is this an aftermarket tach?
Normally you tap off one side of the coil.
If it's a factory tach, it's run via the CCD bus along with the rest of the gauges - the PCM supplies a signal.
Old May 10, 2013 | 12:13 AM
Klokworx's Avatar
Klokworx
ah gotcha, aftermarket. i got that massive fuel gauge where the tach should be.
Old May 10, 2013 | 01:19 AM
98DAKAZ's Avatar
98DAKAZ
Truthfully you don't need a tach I go by feel its not hard to figure out I'm guessing you have a manual trans you are probably doing good now just keep doing it its more ego than a needed Item.
Even when I had a tach I never looked at it
Old May 10, 2013 | 01:41 AM
magnethead's Avatar
magnethead
tap the negative wire of the coil.
Old May 10, 2013 | 06:54 PM
Klokworx's Avatar
Klokworx
ive driven standards all my life, its not just to have one or for ego. i like to check in on my rpm situation once and a while, i can also monitor fluctuations and what not. plus when im driving a standard i like to see the tach there. when driving an automatic, i hate seeing a tach.
Old May 10, 2013 | 08:22 PM
moe7404's Avatar
moe7404
to judge MPG a vacuum gauge works best. a vacuum gauge is the ONLY gauge that tells you the load on the engine. good one are hard to find.
Old May 10, 2013 | 09:58 PM
Klokworx's Avatar
Klokworx
where would this vacuum gauge be plugged into?
Old May 10, 2013 | 10:42 PM
Tom A's Avatar
Tom A
Section Moderator
I also like having a tach, and it has nothing to do with ego. It has everything to do with hitting my shift points when I'm embarrassing some ricer Honda in the stoplight drags.
