Which would be the best traction device?
Old May 18, 2013 | 01:52 AM
Trent479's Avatar
Trent479
Default Which would be the best traction device?
I will be moving up to 35's on my 2wd when I get moved to full time next month after i put on my front end mid travel kit. and I amd switching to 4.56 gears and putting in a locker or limited slip. I cant decide... I can get this http://www.ringpinion.com/b2c/Produc...rce=DiffWizard or this http://www.ringpinion.com/b2c/Produc...rce=DiffWizard. I do a lot of daily driving but im not worried about chirpin tires on a tight turn. i just know i will be hauling a small trailor with 3 dirtbikes about once a month and thats it. fully locked or limited slip?
Old May 18, 2013 | 02:11 AM
jpayne80's Avatar
jpayne80
When I put 4.56s on my 2wd Ram I also added an Auburn LSD. It was great, however I had to relearn accelerating while turning, especially in rain.
Old May 18, 2013 | 10:40 PM
Tom A's Avatar
Tom A
Section Moderator
I have had (on various vehicles) two Auburns, a Detroit Locker, a Lock-Right, a Spartan Locker, some other lunchbox locker (EZ-Locker?), a couple of factory clutch-type limited-slips, a spool, and a Yukon Dura-Grip.
The Auburns were great. Good traction, excellent street manners, and I never broke one. The Detroit Locker was freakin' awesome. Totally unbreakable and unbeatable traction. It was a little quirky on the street, but totally livable. The worst one, by far, is the Dura-Grip I'm running right now. It works fine, but it sounds like the rear end is full of rocks. I've tried conventional oil, synthetic oil, 90 weight, 140 weight, different additives, etc. It still sucks. I'm probably going to end up replacing it with the Detroit I should have bought to begin with. I've already spent more on oil than I saved buying the Yukon.
BTW, the EZ-Locker (or whatever it was) lasted about a year in the back of my Chevy. I don't think I would ever use any lunchbox locker in a rear axle again. They seem to work fine in front axles (ran a Lock-Right in a Blazer with 36" tires for years with no issues and am running a Spartan locker in my front axle right now), but just don't hold up under everyday use (my experience only, YMMV).
Old May 19, 2013 | 01:09 PM
Trent479's Avatar
Trent479
Thanks! I appreciate the comments. I think i will end up goin with the Auburn. But this will be in a few months so i mat change my mind. I just wanted some input. I know Auburn is always good. I just seen some bad reviews about the Spartan.
Old May 19, 2013 | 01:57 PM
magnethead's Avatar
magnethead
I was going to get a Lock-right, but talking to our axle sponsor/local jeep fabricator (BaerTrax), he said I'm best off with an clutch-type limited slip lunchbox locker (I think auburn). I would have gone detroit when i did the gear change, but i was tight on cash, so having to cheap out this time.
Old May 19, 2013 | 03:14 PM
Tom A's Avatar
Tom A
Section Moderator
No problem. Like I said, I've had nothing but good experiences with my Spartan so far, but it's in the front axle, where it only sees occasional use.
In situations where both tires have good traction (like drag racing), limited-slips work great. And the Auburn is nice because it doesn't have any clutch discs to break and go through your gears and bearings.
In off-road situations where one wheel has zero traction (like when it's up in the air), you can't beat a locker.
I bought the Yukon Dura-Grip because I was a little tight on cash and it sounded pretty good, but I'm kicking myself for not just buying the Detroit Locker that I really wanted. Hell, I would have been way happier with an Auburn and I would have actually saved money.
Old May 24, 2013 | 04:45 PM
Trent479's Avatar
Trent479
sweet. yeah i wont touch the rear end till i get the 35's. but i was just lookin online and thought i would get some input.
Old May 26, 2013 | 02:45 PM
Hahns5.2's Avatar
Hahns5.2
Locker without a doubt, LSDs will not help in many off-road situations.
FWIW, I have a Powertrax No-Slip in the back of my truck with over 75k miles on it, daily driven. I did remove the syncrhos from it so it behaves like a standard locker though.
I have Aussie lockers front and rear in my Bronco II, no problems with either but only maybe 10k on it. I did have a used Lock-Right in the stock rear axle and probably put a good 40k on it, until I broke the cross-pin (not the lockers fault).
Old Jun 3, 2013 | 08:09 PM
Dakota~N~Camaro's Avatar
Dakota~N~Camaro
Im running the Auburn Pro LSD in my Camaro and its a lot more aggressive than the regular Auburn, You can feel it on a hard lock turn, I beat the heck out of it, have a real aggressive trans that will lay out rubber on the 1-2 and bark the 2-3 shift so it gets hammered. Always does what its suppose to, got twin tire fire.
I have the OEM Mopar LSD in the Dakota, When I swap to 4.10's I'm going Auburn Pro in the back and the regular Auburn up front.
Old Jun 11, 2013 | 09:48 AM
DakinUK's Avatar
DakinUK
I got a Regular Auburn put in mine when the 4.10 gears went in. I don't do serious off-roading, more like trails and the odd muddy field but the Auburn works well. Much better traction and unnoticeable on the road.
I see that you're thinking of putting something in the front axle. I'd love to be able to that but that's the ONE downside of the AWD system. Can't put any type of LSD/Locker in the front axle. :-(
