Mirror
Old May 18, 2013 | 09:02 PM
Dakota~N~Camaro's Avatar
Dakota~N~Camaro
Default Mirror
Will 1500-3500 mirrors bolt up on a 02 Dakota, or anything that's better for towing than the stock ones??
I have power mirrors now
Old May 18, 2013 | 09:38 PM
dodgeramguy85's Avatar
dodgeramguy85
Im pretty sure the bases are different. They look similar but not sure. You might be able to mod them to work but no guarantees. I can go measure the base on my ram tom if you want.
Old May 18, 2013 | 10:09 PM
Dakota~N~Camaro
Please, maybe a pic or two with the tape measure
Any idea if the mounting studs are the same??
Old May 18, 2013 | 10:21 PM
dodgeramguy85
I did a little searching and they say the bolts are very close but the biggest problem is the base doesnt fit the dakota door contour. I couldnt find anyone post up a write up or pics of it done. A lot of people talk about doing it but no solid proof.
Old May 19, 2013 | 12:06 AM
Dakota~N~Camaro
There has got to be a easy way to do this
Old May 19, 2013 | 12:37 PM
JBs DAK's Avatar
JBs DAK
I can't blow up your truck pic good enough to see your mirror
But, my '99 has what try call tow- package mirrors on it. They
Are larger than stock. Might want to check into those.
Old May 19, 2013 | 04:22 PM
Dakota~N~Camaro
I have the sport mirrors, but have the factory tow package
Old May 21, 2013 | 10:37 AM
DakinUK's Avatar
DakinUK
I too have a "Sport" and found the mirrors rather lacking for towing. I got a set of Regular Dakota/Dorango mirrors from a breakers yard and they went straight on. All the electrics work fine. The mirrors are a good size bigger and have the advantage (for me, in London!) of being foldable. You can also fit these if you need even wider viewing angles.
http://www.truckchamp.com/towing-mir...ies/slide-over
I got some but can't remember where I bought them, pretty sure I didn't pay that much!
Old May 21, 2013 | 03:52 PM
Dakota~N~Camaro
They would bolt up for me, but the plug would be different. 01 and up has a different plug, if they both have the same number of wires I guess I could make it work, but IDK if they do or not
