Ctm problem
Old May 22, 2013 | 12:46 PM
CodyGilson's Avatar
CodyGilson
Default Ctm problem
Hello, I am wondering if anyone knows where I could possibly find the bottom 12 pin connector that goes into my CTM/ALARM Module. I have searched high and low for this connector does anyone have any Idea?
Old May 22, 2013 | 12:56 PM
00DakDan's Avatar
00DakDan
Section Moderator
I'll suggest a boneyard. Otherwise I think it would dealer only.
Old May 22, 2013 | 01:00 PM
CodyGilson's Avatar
CodyGilson
Yeah, I have called the dealer they want $117.00 for it. I might have to just bite the bullet on this one.
Old May 22, 2013 | 01:17 PM
00DakDan's Avatar
00DakDan
Section Moderator
Why not try the junkyard?
I've had good luck finding odds parts there, cheap. You're better off going to one that you can go through the cars yourself though.
Old May 23, 2013 | 11:51 AM
CodyGilson's Avatar
CodyGilson
Very good point however, won't I have to find the exact same truck as mine, same factory options or will all the connectors be the same for every truck?
Old May 23, 2013 | 12:28 PM
00DakDan's Avatar
00DakDan
Section Moderator
The connectors are not specific to each vehicle. In some years, yes, there was a "base" and "premium" CTM but in later years, no. Specific options don't matter. The trucks wiring harnesses are for the most part generic. That's why some vehicles have connectors with nothing in them.
What year are you looking for? I'm guessing '01 or up since earlier years only had two connectors. 2001 up has a 12 pin connector on the CTM. I show no "base" or "premium" variations for those years.
Old May 23, 2013 | 01:04 PM
CodyGilson's Avatar
CodyGilson
I have an 04 base 4wd I need that bottom 12 pin connector
Old May 23, 2013 | 01:10 PM
00DakDan's Avatar
00DakDan
Section Moderator
Look at '01 and up for your connector.
I show only the one style but it could vary between years. If you can compare it to what you have now.
