Normal Oil Pressure?
Old Jun 25, 2013 | 08:04 PM
Jeremy98dakota's Avatar
Jeremy98dakota
Default Normal Oil Pressure?
what is the normal oil pressure range for a 1998 Dodge Dakota 5.2L V8? Mine is at about 60 when cold and driving and at half i think 40 when idling. Today the truck was a little warmer but in park at idle it was at about 30. Is that still normal?
Old Jun 25, 2013 | 08:11 PM
00DakDan's Avatar
00DakDan
Section Moderator
6 psi is the minimum. Yes, six. The general rule of thumb is 10 psi per thousand rpm. It's normal for it to drop a bit when warm.
The dash gauges aren't known for being very accurate. Use a mechanical gauge if you ever think you have a problem.
Old Jun 25, 2013 | 10:40 PM
Jeremy98dakota
ok i kinda thought it was but figured i would ask
