ABS and brake light on
Old Sep 6, 2013 | 03:21 PM
2001DodgeMan's Avatar
2001DodgeMan
Default ABS and brake light on
What would cause the ABS and brake light to come on? Fluid is full and I see no leaks underneath? What do I need to check for,as I need to have my only vehicle on the road?
Edit just found a leak on the inside of the right rear tire.....
Old Sep 6, 2013 | 04:25 PM
2001DodgeMan
I am suspecting the rear wheel cylinder is bad,is it hard to replace(and is there a video showing how to do this as well??)
Old Sep 6, 2013 | 04:36 PM
Robbadodge's Avatar
Robbadodge
I'm guessing this will help you out... It's a RAM, but is probably close enough in my first search.
Knowing how to search is half the solution. Using the quote marks: "changing rear wheel cylinder site:dodgeforum.com"
Google search is much easier than the search on our forum.
Good luck!
Robb
Old Sep 6, 2013 | 04:39 PM
00DakDan's Avatar
00DakDan
Section Moderator
If it is a wheel cylinder they aren't hard to change BUT the hardware can be very corroded. Soak the wheel cylinder bolts and the brake line with penetrating oil overnight if you can. Use a line wrench on the fitting (has more flats).
You may end up changing the shoes if they're wet.
Old Sep 6, 2013 | 06:23 PM
2001DodgeMan
Thanks,I'll probably work on this tomorrow,maybe.
Old Sep 8, 2013 | 01:12 PM
2001DodgeMan
Ding,it was the wheel cylinder....busted.
Old Sep 8, 2013 | 07:49 PM
pigcatshiner's Avatar
pigcatshiner
so you now know what it was..I would have never guess it to be a wheel cylinder..Why would that cause the light to come on? My light is on as well...Has been for a long time..
Old Sep 8, 2013 | 09:01 PM
00DakDan's Avatar
00DakDan
Section Moderator
A failure in the base brake system will trip the ABS and BRAKE warning lights.
Old Sep 9, 2013 | 06:54 AM
pigcatshiner
how do you know if it is bad .if there is no fluid leaking,how do you know?
Old Sep 9, 2013 | 08:55 AM
00DakDan's Avatar
00DakDan
Section Moderator
If the ABS light is on you can get it scanned.
Start off with a thorough examination of the brake system. How are the shoes/pads? Is the pedal firm or does it "sink" to the floor? Is it pulling? Do you smell "burning" from any of the pads.
