Crankshaft sensor swap! NEED HELP
Old Sep 9, 2013 | 02:49 PM
Mr.D's Avatar
Mr.D
Question Crankshaft sensor swap! NEED HELP
code is reading P 0340 which from research means no reading from the crankshaft sensor. Is this something i could do myself? Im somewhat of an amateur mechanic but never changed a crank sensor. Also, where is this sensor located? Thanks for The help!
Old Sep 9, 2013 | 02:52 PM
sxrsil3nt's Avatar
sxrsil3nt
Very easy job to do. Its 2 11 or 12mm bolts and a connector.
The sensor is located on the back of the engine where your transmission bolts up. You can see it through the passenger side wheel well. Id advise pulling the inner fender out for more room.
The sensor goes into a hole located on your transmission and bolts to the engine.
Old Sep 9, 2013 | 03:22 PM
deck60's Avatar
deck60
check out this video
Old Sep 9, 2013 | 03:37 PM
00DakDan's Avatar
00DakDan
Section Moderator
Hang on gents,
It's the 4.7 he has, not a 3.9, 5.2, or 5.9.
It's on the right rear of the engine. It goes into the ENGINE, not the transmission. There is only ONE bolt.
The tone ring is internal on a 4.7.
Old Sep 9, 2013 | 03:48 PM
magnethead's Avatar
magnethead
Originally Posted by 00DakDan
Hang on gents,
And don't break the sensor off!
Old Sep 9, 2013 | 05:54 PM
sxrsil3nt's Avatar
sxrsil3nt
Oh he's got the 4.7?
Well good catch then Dan.
Old Sep 10, 2013 | 08:18 AM
Mr.D's Avatar
Mr.D
You guys are all awsome! Great advice got me throught it! Thanks again!!!
Old Sep 10, 2013 | 01:08 PM
magnethead's Avatar
magnethead
changed a *.7 crank sensor without breaking it off?
Consider yourself a fairly rare breed :P
Old Sep 10, 2013 | 03:00 PM
deck60's Avatar
deck60
my bad forgot about the changeover to the 4.7 there is a video on utube on the 4.7 when I looked up for 3.9 location
