Big Mikes 98 Dakota 2.5 Reg Cab 2wd Build Thread
Old 12-17-2013, 10:02 AM
Bigboi407's Avatar
Bigboi407
Bigboi407 is offline
im sure i just fixed the problem
  #72
Old 01-07-2014, 05:25 PM
Bigboi407's Avatar
Bigboi407
looks like im gonna bring this thread back to life because im going to rip the head out of my engine AGAIN, and we should be seeing some Very Very damaged valves, I HOPE!!!
ive done just about everything besides a leak down test and a radiator pressure test
  #73
Old 01-09-2014, 08:29 AM
Bigboi407's Avatar
Bigboi407
I am Victorious!!!!!!....
Aaand heres #4 exhaust valve:
Aaaand i couldnt complete this without a few of my friends on the job (BL is a friends):
#4 misfire has been defeated and the engine is running absolutely perfect
  #74
Old 01-14-2014, 09:16 AM
Bigboi407's Avatar
Bigboi407
Engines still running perfectly fine, Now i need to get on to front end bushing and ball joints
  #75
Old 10-03-2014, 07:30 AM
Bigboi407's Avatar
Bigboi407
So its been a lil since ive last posted on these forums, i came across an issue last week, i got pulled over because my brake lights are working improperly, ive changed bulbs with the same result, all my fuses are good
Im assuming its a wiring issue, but idk if theres a common issue on these trucks related to tail light issues...
I turn on the lights, the lights come on, the brake light when u hit the pedal, doesnt work, even hazards work, but not when i touch the brake pedal, the light on the P/S doesnt brighten or anything at all, just stays lit, this must have just happened recently, because i live in a VERY Strict area, in certain areas you cant even do 5mph over the speed limit, and in certain areas, you even get pulled over for not being white, (I am not a racist, not picking any race, just speaking from Experience) but if your anything but white, your automatically "Suspicious".....
So i need to get my light figured out because ive been pulled over twice now in less than a week, THEN my headlight went out due to it getting wet, but thats another issue in itself thats not too difficult to fix, just need another housing
i need to fix my dakota because i will be selling it in the next month or two, im buying a Jeep Comanche 4.0 5spd, the 2.5 isnt enough power for me, and the comanche is gonn be at a price i cant refuse
  #76
Old 10-04-2014, 02:42 PM
DurdyGP's Avatar
DurdyGP
DurdyGP is offline
Change the the headlight switch mines did the same thing it was the head light switch you need to add a relay ill see if i can find diagram some guy on FB dakota page gave me
  #77
Old 10-04-2014, 09:34 PM
Bigboi407's Avatar
Bigboi407
ive blown 3 headlights in a few days time, im guessing the headlight housing is toast
  #78
Old 10-05-2014, 09:59 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Thumbs up
Good luck with the Jeep Comanche 4.0 5 spd. yea the 2.5 is no powerhouse that's for sure. I want to get newer Dakota around a 2006 to 09 with either the 3.7 or 4.7 as this time I want more cab room not a standard cab not sure on a stick or auto an auto may suit me better as I'm almost 60.
  #79
Old 10-07-2014, 10:01 AM
Bigboi407's Avatar
Bigboi407
This morning i decided to check my dakota for codes, as i am running a 99 cluster with a Tach, the CEL is Always on due to some unknown compatibility issue between the 98 and 99 models
so i was thrown my usual P0420, since i just cut my exhaust pipe, i am convinced my cat is hollowed out
But then a P1682 Code appeared, and the code reads as follows, and im rather confused
P1682 Charging System Voltage Too Low
  #80
Old 08-25-2015, 11:15 PM
Bigboi407's Avatar
Bigboi407
Seeing as i use my truck EVERYDAY and intend on keeping it as my work truck for years to come, i am finally at the point where i need to change the ball joints, control arm bushings and shocks, i already have the control arms with red bushings installed, i am going to order some ball joints, going to order moog ball joints from rock auto and i need shocks, but i dont have any idea what to get, cheap ones are $20-30, going to look into what i should use, i also got fenders and a grill, im going to get a bed and repaint my truck
Quick Reply: Big Mikes 98 Dakota 2.5 Reg Cab 2wd Build Thread
