2wd to 4wd questions
Old Sep 20, 2013 | 11:54 PM
01dak3.9's Avatar
01dak3.9
Do you think I could keep the stock front end with 35s and 7" of lift?
Old Sep 21, 2013 | 12:01 AM
Tom A's Avatar
Tom A
Section Moderator
You mean install an IFS on your 2WD truck with 7" of lift? I think that would be a ton of work. It would actually be easier to swap frames. An SAS is much more practical, IMO.
Old Sep 21, 2013 | 12:04 AM
01dak3.9's Avatar
01dak3.9
No, I mean can I sas it and keep the stock front bumper?
Old Sep 21, 2013 | 12:11 AM
Tom A's Avatar
Tom A
Section Moderator
Sure, no problem. I ran my stock bumper for a while before I built the one I have now.
Old Sep 21, 2013 | 12:13 AM
01dak3.9's Avatar
01dak3.9
Ok thanks.
Old Sep 21, 2013 | 12:18 AM
Tom A's Avatar
Tom A
Section Moderator
No problem. Good luck.
Old Sep 21, 2013 | 12:33 PM
01dak3.9's Avatar
01dak3.9
Oh and will rack and pinion work with sas?
Old Sep 21, 2013 | 12:38 PM
Tom A's Avatar
Tom A
Section Moderator
Nope. Or at least not without a lot of work and custom fabrication. Fortunately, it's not that difficult to install a steering box (I think older F-250 trucks are popular donors.
I was lucky that mine came with a steering box instead of rack and pinion.
Old Sep 21, 2013 | 10:55 PM
01dak3.9's Avatar
01dak3.9
Do you know what axles are the right length? I don't really feel like narrowing a axle.
Old Sep 21, 2013 | 11:15 PM
Tom A's Avatar
Tom A
Section Moderator
My wheels have like 5" of backspacing, so the wide track J10 axle was perfect. So was the full-width Chevy rear axle. For wheels with less backspacing, the narrow-track Wagoneer axles work well. I've also heard of people using axles from full-sized Broncos (before they went to the TTB, obviously). In fact, using the whole radius arm setup from the Bronco is one of the easiest and cheapest ways to do an SAS.
