01 Dakota
Old Oct 21, 2013 | 06:10 AM
mark.goderre's Avatar
mark.goderre
Default 01 Dakota
White smoke billowing out of exhaust, temp guage maxed out. Just put a new water pump in
Old Oct 21, 2013 | 07:50 AM
Dodgevity's Avatar
Dodgevity
Unfortunately, that sounds like a blown head gasket or cracked head. Did it overheat prior to the water pump? The smoke you described sounds like coolant burning. Check the oil, does it look milky or contaminated?
Old Oct 21, 2013 | 09:35 AM
98DAKAZ's Avatar
98DAKAZ
Pump must have been bad or it was installed wrong.
Your temp must have started out ok why didn't you pull over as you saw the temp get high?
Never assume any new part is good I always inspect any part I get look for any defects/cracks or discoloring if a moving part see if it does what its suppose to do before you install it.
It sounds like you just burned the engine up
I have seen bad new batteries, radiators, rad caps, oil filters, clamps, tools, shocks, pinion gears, bearings, A/C condensers, tires the list is very long.
Especially now that 99% of all parts come from China
Old Oct 21, 2013 | 09:44 AM
00DakDan's Avatar
00DakDan
Section Moderator
What engine is it Mark?
Old Oct 21, 2013 | 10:10 AM
98DAKAZ's Avatar
98DAKAZ
Did you burp the system?
Burp means make sure all the air was out of the cooling system this can cause the cooling system to not function at all depending.
Always check any new water pump or radiator after install with the rad cap off run the engine till you see the thermostat open and watch the coolant flow.
An air pocket can cause the coolant to not flow.
Old Oct 22, 2013 | 06:58 AM
mark.goderre
Thanks everyone. Head gasket blown. Was blown from the start just didn't know it
Old Oct 22, 2013 | 09:27 AM
Dodgevity's Avatar
Dodgevity
Sorry to hear. Are you going to fix it, get a new engine or ditch the truck?
Old Oct 23, 2013 | 07:17 AM
Marksfree's Avatar
Marksfree
New Member
Default In shop
With the job and school it is up to the shop to fix the head gaskets. Wallet is getting slammed but like my truck.
