ABS noise, no light
Old Oct 21, 2013 | 10:52 PM
martinpc's Avatar
martinpc
Default ABS noise, no light
I have recently bought an 02 QC Dak. Love this truck! But...
When I brake hard sometimes the brakes just let go for a second. I can also hear a clicking noise. At first I thought it was in time with the wheels, but it isn't.
I'm pretty sure it's ABS because I pulled the fuse under the hood for it and the noise and behavior goes away.
Any ideas? Speed sensor?
Old Oct 22, 2013 | 03:56 AM
sl2racer's Avatar
sl2racer
i have had this same problem. i never have done anything about it though.
Old Oct 22, 2013 | 02:58 PM
magnethead's Avatar
magnethead
sounds to me like the ABS is working "normally". That said, I can go from 50 to 15 in about 3-5 truck lengths and ABS never kicks in that I can feel. But if I drag the brakes then deck it, I'll hear the solenoids popping.
Old Oct 23, 2013 | 07:46 AM
martinpc's Avatar
martinpc
The noise I can get over. The weird lurch that causes an uncontrolled stop I really don't like.
Old Oct 25, 2013 | 10:42 AM
Robbadodge's Avatar
Robbadodge
Remove the sensor and clean it (them).
Old Oct 27, 2013 | 01:09 AM
sl2racer's Avatar
sl2racer
where are they?
Old Oct 27, 2013 | 09:07 AM
98DAKAZ's Avatar
98DAKAZ
If you have all wheel ABS it could be one of the front sensors has a problem.
Just a guess
Old Oct 28, 2013 | 04:20 AM
sl2racer's Avatar
sl2racer
mine only has rear abs.
Old Oct 28, 2013 | 08:13 AM
martinpc's Avatar
martinpc
Default research
I'm almost positive I don't have four wheel abs. From what I've gathered:
02 Dak only had rear wheel abs
There's only one sensor for the rear
If any one wheel looses traction, it releases all four brakes
When I took the fuse out, I didn't have any of the strange releases of brakes. But one back tire very easily lost traction.
So new tires fixed most of my problems. The Wild Country brand tires just weren't cutting, even though they still have two quarters worth of tread left.
Now on to shocks. Any recommends?
Old Oct 28, 2013 | 09:45 AM
00DakDan's Avatar
00DakDan
Section Moderator
4 wheel ABS was available in '04.
Rear wheel ABS only affects the rear wheels, not all 4. If 4 wheel ABS it will work on either front or both rear, depending upon what's going on. It should not "lurch."
Contact Dodge for a build sheet, it'll let you know exactly what you have.
https://dodgeforum.com/forum/2nd-gen...-my-truck.html
