Coolant Temperature Sensor - where
Old Nov 15, 2013 | 05:05 PM
ardisk_51's Avatar
ardisk_51
Default Coolant Temperature Sensor - where
I have a 1999 Dodge Dakota 3.9. I think I have located the ECT sensor, but the one O'Reilly's sold me is a lot smaller on the Hex section. I hesitate to take the one out before I know I am in the right area of the engine.
I think it is located on the right front side of the manifold just behind the alternator. Am I right? Has a black plastic connector on it.
Thanking you in advance.
Old Nov 15, 2013 | 05:16 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum.
Right side, behind the alternator is the correct location. Aftermarket sensors can be different in appearance.
Old Nov 15, 2013 | 05:23 PM
ardisk_51's Avatar
ardisk_51
Thank you. Can this also be called the IAT Sensor? I am confused.
Old Nov 15, 2013 | 05:37 PM
sxrsil3nt's Avatar
sxrsil3nt
The IAT and Coolant Temp Sensor look almost identical on the 3.9
The IAT has a small hole on the bottom of the brass and is slightly bigger.
The Coolant Temp sensor has no hole on the brass and is smaller.
IAT:
Coolant Temp Sensor: Note the back of the alternator on the right side
Here's a side by side comparison of the coolant temp sensor and the IAT
NOTE: This is the 5.2L Coolant Sensor, the 3.9 sensor is smaller:
Old Nov 15, 2013 | 06:43 PM
ardisk_51's Avatar
ardisk_51
Oh, thank you so much! I love pictures. They make things so clear. Now I have to get the air compressor hose out to the truck to blow all the maple seeds, etc. from around the area so I can get to the part.
Not gonna' happen today. Raining, windy and cold here! Plus I have to re-sew the sleeve and sew the sleeve back onto the glove on my husband's sand blast glove.
Ardis
Western Washington State
Old Nov 15, 2013 | 07:27 PM
sxrsil3nt's Avatar
sxrsil3nt
No problem.
Easy job, but bit of a pain to get to.
Lots of stuff in your way - good luck!
Old Jun 24, 2014 | 11:54 AM
artgeor's Avatar
artgeor
Default ECT Sensor
Can the vehicle be driven without the ECT sensor in place?
2002 Dodge Dakota 3.9
Old Jun 25, 2014 | 09:25 PM
KillerKilgore's Avatar
KillerKilgore
No, lose coolant.
