Lift
Old Dec 6, 2013 | 06:08 PM
Babyzila1's Avatar
Babyzila1
Default Lift
I have a 03 Dakota slt and i was looking at lifting it with a add a leaf kit from tuff country but it's ony a 2.5 could I put 2 on to make it a 5 inch lift
Old Dec 6, 2013 | 06:52 PM
TheNewbie's Avatar
TheNewbie
Even if you did how would you lift the front to match?. I'd look into a body lift to go along with that.
What are you trying to accomplish with this truck? Are you trying to clear a certain size of tire? Just want it taller for looks?
Old Dec 6, 2013 | 10:30 PM
Babyzila1's Avatar
Babyzila1
I want to try to clear 35s but if not maybe 33s
Old Dec 6, 2013 | 10:35 PM
Babyzila1's Avatar
Babyzila1
What would be the cheapest way to lift it 5 to 6 inches
Old Dec 6, 2013 | 10:43 PM
Babyzila1's Avatar
Babyzila1
Could I use leveling kit and spacers
Old Dec 6, 2013 | 10:48 PM
magnethead's Avatar
magnethead
suspension lift kits do not exist for our trucks because the front suspension/steering design does not allow it. You're limited to what you can do with the springs/torsion bars, a body lift, or all-out SAS.
Old Dec 6, 2013 | 11:30 PM
dodgeramguy85's Avatar
dodgeramguy85
Crank the torsion bars and 3in body lift and you will be able to clear 35's. What kinda engine do you have. If its not a v8 its gonna suck turning those big tires.
Old Dec 7, 2013 | 12:06 PM
TheNewbie's Avatar
TheNewbie
For 35's I would crank the torsion bars about 2" and get a 3" body lift. That is really the only way you can get that much lift.
I'm running 33x10.50's and they even rub on the frame when turning.
Old Dec 7, 2013 | 03:39 PM
Babyzila1's Avatar
Babyzila1
Are there any other ways to get it lifted for cheap
Old Dec 7, 2013 | 04:36 PM
TheNewbie's Avatar
TheNewbie
The only cheap option is a body lift. Period...
There are several ways to lift the rear. You could do a block lift, shackles, add a leaf, lift springs and if you're a good welder you could even modify the shackle hangers. But the front is the problem. If you do a search for lift kits you'll find tons of options for the rear, but the front doesn't have the same options due to the IFS. A body lift is the only way to lift the whole thing more than an inch or 2. You might be able to get more out of a torsion crank, but then you'll start losing CV axles and other front end parts way to quickly.
Other than that you are limited to doing a solid axle swap, which is NOT cheap or easy.
