cv shaft c clip?
Old Dec 27, 2013 | 07:27 PM
dakota5.9's Avatar
dakota5.9
Originally Posted by 00DakDan
Take a look at the old and new shafts. If I recall, there were changes in the design over the years and they moved the c-clip position forward a bit I think.
The change happened sometime between the '00 and '01 model year. Someone may have mixed up the axle.
autozone took the old axle for a core.
Old Dec 27, 2013 | 08:04 PM
dakota5.9's Avatar
dakota5.9
I tried pulling the cv shaft off of the axle stub but the stub came out with the cv shaft. had to put it in a vice the last time gues ill have to do that again. be about the 4th or 5th time ive had this apart lol
Old Dec 29, 2013 | 02:03 AM
dakota5.9's Avatar
dakota5.9
Anyone know for sure if they moved the c clip position on these? It looks like its to far out and that may be the problem. Either way it ate up my stub shaft....winder if autozone will pay for the new stubshaft.
Old Dec 29, 2013 | 09:48 AM
00DakDan's Avatar
00DakDan
Section Moderator
They did change them, between 9/11/00 and 9/12/00. Of that I am positive.
Prior to 9/11/00 it was a 1 5/16" deep from the end of the "female inboard housing."
What year is your Dakota? It is also possible that it was assembled from the incorrect components or mismarked.
Old Dec 29, 2013 | 01:33 PM
magnethead's Avatar
magnethead
Pretty bad when you can pinpoint the day that things switched over.......
Old Dec 29, 2013 | 02:13 PM
00DakDan's Avatar
00DakDan
Section Moderator
Not really.
Check Rockauto and they have the change over date listed.
Old Dec 30, 2013 | 06:07 PM
dakota5.9's Avatar
dakota5.9
yep autozone gave me the wrong one, wich in turn ate up my splines on my stub shaft, so know the dealership charged me 100 bucks for a new stubshaft and had to order a new cv shaft. autozone wont pay for the stubshaft either and they took my core so now im out 150 bucks on a new cv shaft!!!!
