lean, and pull
Old Jan 9, 2014 | 05:50 PM
t.storey's Avatar
t.storey
Default lean, and pull
so im hoping its not what i think it is. my truck constantly pulls to the left, hard only on occasion. also it has a noticeable lean. i measured and the front driver side is an inch lower than the passenger front. the rear driver side is 1/2 an inch lower than the rear passenger side.
Old Jan 9, 2014 | 07:39 PM
atthewmartin114's Avatar
atthewmartin114
check tire pressures and check alignment. also you may need to tighten the torsion bar a little to adjust the ride height.
Old Jan 9, 2014 | 07:47 PM
dodgeramguy85's Avatar
dodgeramguy85
Jack the truck up and see if anything is loose. Have you owned the truck since new.
Old Jan 9, 2014 | 09:05 PM
t.storey's Avatar
t.storey
see i was thinking it may be t bar but why would that just loosen itself? and tire pressure is fine, alighnment however idk. previous owner (answers the dodgeramguy85's) said he just did balljoints but idk if he did tierod ends too. im having tires put on fairly soon so ill see if theyll check alignment too. its too cold here in michigan to just go outside and jack the truck up
Old Jan 9, 2014 | 11:30 PM
dodgeramguy85
I've saw trucks sag on that side from heavy drivers thats why I asked. It would be different if just the front leaned on one side not both front and rear.
Old Jan 9, 2014 | 11:55 PM
magnethead's Avatar
magnethead
Do this.
Take a tape measure, and go measure the height of the front/rear leaf spring bolts. This removes almost all non-suspension variables in back. Also, are you measuring with the fuel tank full or empty? A full fuel load is around 150 pounds, plus the driver's weight.
Where are you measuring at? The fenders or the frame rails? Something as simple as worn body bushings or rotted cab mounts can make the body unlevel.
Once you have the height of the 4 leaf spring bolts, measure the front of the frame rails. The bumper mounts are slotted, so those won't work. You'll have to go in through the fenderwell or something.
Old Jan 10, 2014 | 04:18 PM
t.storey's Avatar
t.storey
i measured from the top of the tire to the top of the wheel well, looked today and leaf springs, hangers, shackles all are together, rusted, but together. the front i cant see much of. tomorrow im going to try to get under the truck and ill check my torsion bars
Old Jan 10, 2014 | 06:04 PM
TheNewbie's Avatar
TheNewbie
I doubt that it loosened itself. But the torsion bar is basically just a big spring. Like any spring, it can wear out with use. All you have to do to raise or lower the front of the truck is turn one bolt.
As for the rear, there isn't alot you can do to adjust just one side. You COULD but it would be a bandaid for a bigger problem. But when you get the measurements these guys have asked for we will know a lot more about WHY it's not sitting level. Knowing if the frame is is sitting level will let us rule out things like body mounts.
Old Jan 10, 2014 | 09:18 PM
Tom A's Avatar
Tom A
Section Moderator
If the left front is sagging, it will cause the left rear to sag, too. Otherwise, the frame would have to twist for the rear to remain level while the front leans.
Old Jan 10, 2014 | 09:53 PM
t.storey's Avatar
t.storey
so it dosnt sound like bent frame then? idk if i already said it but im actually working on the truck tomorrow so maybe ill find the problem
