SOL! With trying to find the right Driveshaft
Old Mar 5, 2014 | 08:45 AM
Dodgevity's Avatar
Dodgevity
Originally Posted by RDuck
OEM vs Custom? So wtf is the difference?
Among other reasons..... having to deal with shops like the one you're ranting on and other people who "build driveshafts at work daily."
Old Mar 5, 2014 | 05:08 PM
RDuck's Avatar
RDuck
Yes, I work in a heavy truck shop. Yes we build driveshafts and pto shafts on a daily basis.
I personally don't but we have a guy here and its all he does eight hours a day.
I do take my own measurements for the shafts I need built when I'm stretching or shortening a truck or installing pneumatic blowers and oilfield pumps.
I may know something about this.
But hey, can't help some people.
Old Mar 5, 2014 | 07:46 PM
Dodgevity's Avatar
Dodgevity
What type of metal are you fabricating these driveshafts from?
Old Mar 5, 2014 | 08:26 PM
rebeltaz83's Avatar
rebeltaz83
i had an aluminum shaft made for $300 bucks. they couldn't do steel because it was to long, without being a 2 piece shaft...... slip yolk was from a 68 plymouth, and the rear yolk was out of a 92 dakota. did a v8 swap, used the 318 and 727 out of the car. stuck the slip yolk in, pulled it out an inch, and did my measurement, took it to the driveshaft place, told them what i had, and what i needed, and 3 days later i had a 4" aluminum driveshaft over 70 inches long....... it's a long bed dakota that was 4wd, and a 2wd trans from a fury, didn't want the weaknesses of a 2 piece shaft.
Old Mar 5, 2014 | 08:29 PM
magnethead's Avatar
magnethead
that's how you're supposed to do it. Put the slip yoke in, pull an inch, and measure eye to eye.
Old Mar 5, 2014 | 08:49 PM
Tom A's Avatar
Tom A
Section Moderator
Here's how to measure. From Tom Woods.
Old Mar 5, 2014 | 09:08 PM
Dodgevity's Avatar
Dodgevity
Better off. That's major weight reduction. My QC's OEM shaft is aluminum.
Old Mar 5, 2014 | 09:32 PM
98DAKAZ's Avatar
98DAKAZ
That's strange my Dakota has a very long drive shaft and its metal? I want to swap it out for an aluminum one to help out with my 2.5 less spun weight.
Old Mar 5, 2014 | 09:57 PM
magnethead's Avatar
magnethead
my 01 is steel, i think in 02 or 03 they went to aluminum. A steel driveshaft will pretzel while an aluminum will shatter like glass.
Old Mar 5, 2014 | 10:19 PM
Dodgevity's Avatar
Dodgevity
I've heard the quad cabs come with aluminum shafts to reduce the weight created by extra doors and seats. Not sure if any other Dakotas have it. Regardless, my QC feels heavy. When moving off from a stop, the feeling of inertia that needs to be overcome is quite noticeable. I tested rolling in neutral many times to make sure my brakes weren't dragging, until I got used to it.
