Overdrive solenoid.
well let me explain better. you get in, start the truck. idles fine. then you hear a "tap tap tap tap" as if it was tapping with the engine. i thought at first a bearing. but my engine is running fine, no power loss, from under the hood you dont hear it. but you walk along the side of the truck you hear it. sounds like it's the bottom of the engine or front of the tranny. as for it disapearing once i give it throttle. it depends how much throttle. alot, yes. very little no.
so pull the inspection plate and check the bolts?
Yeah it's 2wd. i gotta wait for all this rain to quit before i go crawling around. Just a thought, if the bolts on the tc are loose, could that be the result of having no OD? like.. maybe not getting enough pressure to lock up? also the other day when i was pokin' around underneath my truck. on the driver side of the transmission, there is a plugin near the tail. the wires are abit tarnished and split. im going to get that fixed asap but is that to the OD unit? here is a photo.
the plugin at the very back i believe.
![](https://dodgeforum.com/forum/attachments/2nd-gen-dakota-tech/23716-overdrive-solenoid-xlbgi1.jpg?dateline=1396053645)
Try cleaning off wires/rubber/plastic to remove grease oil road grime and then coat with liquid tape.
Just a thought.
My 3.9 "taps" like a lifter but I found the exhaust manifold bolts broken on cylinder 3. Would like to get it fixed but afraid of breaking off more bolts trying to extract the already broken ones.
Just a thought.
