View Poll Results: What would yo do?
Reman long block - $2300
1
20.00%
2 heads and timing - $1200
2
40.00%
Just replace the bad head - $420
2
40.00%
Replace the bad head and work towards a Hemi swap in the future
0
0%
Voters: 5. You may not vote on this poll
What would you do? New motor?
Old May 20, 2014 | 01:19 PM
TheNewbie's Avatar
TheNewbie
And I haven't pulled the head yet, but I did remove the intake manifold and pop the valve cover off. Hopefully I will take the head off next Monday.
This is what I found.
The rocker arm had fallen off. It was a bit chewed up.
Old May 20, 2014 | 01:40 PM
Dodgevity's Avatar
Dodgevity
Originally Posted by TheNewbie
Really? Pulling the motor out and having the block resurfaced seems like a lot of unnecessary work for a simple head swap. Why do you say the block would warp from a dropped valve seat?
Put a straight edge on it.
Old May 20, 2014 | 02:22 PM
98DAKAZ's Avatar
98DAKAZ
Looks good very clean they must have used synthetic oil no sludge.
My guess valve froze and lifter snapped off
Could be bad luck or engine overheated or just simply a bad part failed.
Looks promising I wonder if just replacing the lifter would work depends on if the valve is stuck or not I guess.
Was their a valve spring in there? Looks like the valve keeper came off and spring flew off If I'm seeing things correct.
Old May 20, 2014 | 09:41 PM
Tom A's Avatar
Tom A
Section Moderator
The valve appears to be stuck open (for various possible reasons, including a valve seat falling out), which would cause the rocker arm to flop around loose until it fell out.
And I've seen engines with well over 300k miles that NEVER used synthetic oil and they're just as clean inside. It's lots of short trips that make your engine all yucky inside.
Old May 21, 2014 | 09:57 AM
TheNewbie's Avatar
TheNewbie
Yeah, it did look pretty clean and sludge free. And the valve spring was still in place. Just the rocker arm was loose.
Old May 21, 2014 | 10:29 AM
98DAKAZ's Avatar
98DAKAZ
Thumbs up
If the valve is ok you may have an easy fix check the hydraulic lifter be sure its ok.
Old May 21, 2014 | 11:03 AM
TheNewbie's Avatar
TheNewbie
I understand the basic principal of how the valves and lifters work, but I've never really worked on them before. I've only ever pulled heads and replaced them or had a professional shop do the valve job.
What should I be looking for?
I'm still guessing it does have a dropped valve seat as the mechanic at the dealership reported, but that would be cool if I didn't have to pull the whole front of the engine off and screw with the timing. Either way I'll be out of town for the next 4-5 days so It'll have to wait til then. I really appreciate the help though guys!
Old May 21, 2014 | 11:10 AM
Tom A's Avatar
Tom A
Section Moderator
[QUOTE=TheNewbie;3167179]I understand the basic principal of how the valves and lifters work, but I've never really worked on them before. I've only ever pulled heads and replaced them or had a professional shop do the valve job.
What should I be looking for?[/URL QUOTE]
If the valve is hanging open that much, there's a good chance it contacted the piston and did a bunch more damage. The mechanic with the bore scope would have been able to see this, but that doesn't mean the seller would tell you about it.
Old May 21, 2014 | 11:39 AM
98DAKAZ's Avatar
98DAKAZ
Old May 21, 2014 | 11:40 AM
00DakDan's Avatar
00DakDan
Section Moderator
Pull the head and see what damage there is.
The rest of the engine looks clean so far. Maybe you can get away with just the heads - time will tell.
