Gabriel Shocks
Old Jun 28, 2014 | 05:29 PM
Fairway551's Avatar
Fairway551
Default Gabriel Shocks
I have a 2001 Dakota 4X4 extended cab and need new front shocks. Two questions:
1. Does anyone have experience with Gabriel Max Control Monotube Shocks (77905)? I was looking at Bilsteins, but they are crazy expensive.
2. I had the front tire off and looked at the mounting location. It looks like an easy install. Is it? Is there any way to get screwed during installation?
Thanks for your help.
Old Jun 28, 2014 | 10:41 PM
sxrsil3nt's Avatar
sxrsil3nt
No experience with Gabriel's, but a popular shock on this forum that a lot of people have(including myself) are Monroe Reflex's at $37 a piece on Rockauto.
Quite happy with them.
And the install is quite simple, you may have a difficult time getting to the top shock bolt for the rear but its definitely doable. Front's were quite simple.
Edit: Just realized you said you were doing fronts only. Yes they are quite simple and you shouldn't run into any troubles.
Old Jun 29, 2014 | 12:13 AM
archemedes74's Avatar
archemedes74
I've used gabriel shocks, they are ok cheap replacements, the monroes are a better quality in my experience
Old Jun 29, 2014 | 08:50 AM
00DakDan's Avatar
00DakDan
Section Moderator
I'm using the Monroe Reflex too. No problems.
Old Jun 29, 2014 | 01:24 PM
Brian in Tucson's Avatar
Brian in Tucson
I've had at least 3 sets of KYB shocks & struts (different vehicles) over the years and I've been happy with them.
Check out the selection at Rockauto.com. If you order, google 'rockauto discount code' for 5% off the final parts total, but not shipping. Rockauto is the best!
Old Jun 29, 2014 | 01:40 PM
Fairway551's Avatar
Fairway551
Thank you everyone for your helpful comments. I ordered front and rear Monroe Reflex shocks. I'll update this post after installation.
Old Jun 29, 2014 | 02:17 PM
01SilverCC's Avatar
01SilverCC
I had Reflex on my truck too, they were a great shock with excellent ride quality/handling. If Monroe still made the Reflex for a 2 wheel drive Dakota I would still be using them. Now I have Gabriel Ultra's and have been very happy with them, they are the most similar to the Reflex that I have found.
Jimmy
Old Jun 30, 2014 | 02:23 PM
LIZZRD's Avatar
LIZZRD
Reflex here also...
Old Jul 1, 2014 | 10:22 AM
stefanwlsn's Avatar
stefanwlsn
I have the Gabriel Max shocks all around and I love them. They are firm, but not uncomfortable. Good for off-road use.
Old Jul 14, 2014 | 10:08 AM
Fairway551's Avatar
Fairway551
Just got the four Monroe Reflex shock installed. The lower bolts on both rears and left front were corroded to the point that a torch had to be used to break the seized threads. It was a PIA, but now they're in and the ride is MUCH improved. Thanks to all for suggesting these shocks.
