Problems electrical connection 98 dakota transmission AX15
Old Sep 21, 2014 | 09:20 AM
Dinko's Avatar
Dinko
New Member
Default Problems electrical connection 98 dakota transmission AX15
Hello friends, I am new to the group, I need your help, I have a dakota 98 3.9 4x2, which want intalarle one ax-15 transmission, what I'm encountering is in electrical connection, as I can fool the computer, if anyone has a diagram of how to make the connection, I would appreciate greetings from chile
Old Sep 21, 2014 | 04:07 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum Dinko.
Are you removing an automatic and putting in the AX-15?
What connections are you having trouble with?
Old Sep 21, 2014 | 09:29 PM
Dinko's Avatar
Dinko
New Member
Excuse my English, as I donot modify the circuit reached the automatic transmission to turn the truck with AX15 transmission
Old Sep 21, 2014 | 09:35 PM
Dinko's Avatar
Dinko
New Member
Sorry for my English, as I modify the circuit that reaches the automatic transmission, to turn the transmission AX15
Old Sep 21, 2014 | 09:55 PM
00DakDan's Avatar
00DakDan
Section Moderator
The wiring harness is different, auto to manual (AX-15) as is the PCM (the engine computer). On an automatic transmission the PCM controls some functions, like the torque converter lockup. You'll need a new PCM for the AX-15 or will get codes. It should still run though.
The only connection on the AX-15 should be for the backup lamp switch.
You can modify the harness to work with it. If the wire colors didn't change (don't have a manual for a '98), the brown with light green striped wire should be the feed for the backup switch, the violet with black stripe is the output to the backup lights.
The black with white stripe wire is the neutral safety switch. To bypass it just connect it to ground.
Old Sep 21, 2014 | 10:27 PM
Dinko's Avatar
Dinko
New Member
By modifying the harness is not necessary to change the pcm? And when you connect the 4 ground wires do not need to make another connection?
Old Sep 22, 2014 | 09:09 AM
00DakDan's Avatar
00DakDan
Section Moderator
You'll still need to change the PCM. You'll have trouble codes if you don't because it will be looking for inputs from the automatic that you no longer have.
The only connections for the manual are the backup lamp, the two wires. You'll have to ground the neutral safety lead just to bypass it so you can start the truck - that should be it.
Old Sep 22, 2014 | 09:38 PM
Dinko's Avatar
Dinko
New Member
The manual pcm the first generation 95 96, can be installed in a 98 or has to be the same year?
Old Sep 23, 2014 | 09:20 AM
00DakDan's Avatar
00DakDan
Section Moderator
Same year. There are big differences in the PCM's, especially with regards to the on board diagnostics.
