Engine problem
Old Sep 22, 2014 | 11:08 AM
dakota24's Avatar
dakota24
Default Engine problem
Having trouble with engine bolting up to tranny. Engine sitting on motor mounts but their seems to be a gap between tranny and engine. Could tranny have shifted when taking engine out?
Old Sep 22, 2014 | 11:33 AM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum Dakota24.
We need more information. What engine and transmission? If a manual, did you pull the clutch?
Old Sep 22, 2014 | 12:57 PM
magnethead's Avatar
magnethead
transmission shouldn't shift backwards since it's bolted at the crossmember, but it is a soft mount so it could have moved 1/4" or so. Were you able to get the transmission lined up on the dowels at the back of the block?
Old Sep 23, 2014 | 08:11 AM
dakota24's Avatar
dakota24
3.9L Automatic
Old Sep 23, 2014 | 09:18 AM
00DakDan's Avatar
00DakDan
Section Moderator
Did you remove the torque converter? Are you sure it is fully seated on the transmission? You need to push on it while you turn it to get it to seat. Even if you didn't remove it, it could have slid forward.
Old Sep 23, 2014 | 11:13 AM
dakota24's Avatar
dakota24
No. It's just touching the engine.
Old Sep 23, 2014 | 11:17 AM
dakota24's Avatar
dakota24
Removed the engine to do an overhaul. Think I pushed tranny back whille putting it back in. Just wondering if it is possible.
Old Sep 23, 2014 | 11:40 AM
Dodgevity's Avatar
Dodgevity
Are the holes lined up at least? Maybe use some long bolts long enough to catch and pull them together?
Old Sep 23, 2014 | 12:14 PM
sxrsil3nt's Avatar
sxrsil3nt
Tranny my sag a little. Place a jack under the tranny pan and use a piece of plywood to even out the weight so you don't put a hole in the pan.
Jockey the tranny and engine till they are level and make sure the dowels line up. I actually punched the dowels out on mine since they were so rusty. 2 mins on the grinder and poppies em back in. Good as new.
Old Sep 23, 2014 | 04:31 PM
magnethead's Avatar
magnethead
The torque convertor should sit about 3/4" behind the front of the bellhousing. If it came forward any on the input shaft, you'll have to spin it a bunch of times while pushing back. Should pop 3 times (stator, input shaft, front pump). Then line the bellhousing up on the dowel pins and slide them together.
