Transfer case plug rounded off pls help
Old Oct 27, 2014 | 07:28 PM
tspeed109's Avatar
tspeed109
Default Transfer case plug rounded off pls help
On my 04 dodge dakota I tried to get the fill plug out of the transfer case and the allen wrench just rounded out. Now I dont have anything to turn it out with.
any help will be greatly appreciated. I dont have a welder but will Jb Weld work if I put a bolt in the hole and wait a couple days then back it out with the bolt?
anyone in my area please come over and do it for me I will pay you $50.00 to do it.
Nobody will even try to help here.
thanks in advance
Troy B
Old Oct 27, 2014 | 08:01 PM
Wow...thats a tough one....looks like you cant even get a pair of vise grips in there....Only thing I can offer is to drill a hole through it and use an easy out. Then replace the plug.
Old Oct 27, 2014 | 08:21 PM
00DakDan's Avatar
00DakDan
Section Moderator
That'd be my suggestion too, drill and an easy out.
You really can't find a garage to do that? It should be a quick repair up on a lift.
Old Oct 27, 2014 | 08:24 PM
magnethead's Avatar
magnethead
x3 on easy out/drill
Old Oct 27, 2014 | 08:48 PM
tspeed109's Avatar
tspeed109
Default yep no one wants to try that one here
I cannot get a garage to do it because they all say, What If
what if I cant get it out? what if I break it and make a bigger mess for ya.
so Ok what easy out kit do I get to do this?
I have looked at menards, lowes harbor freight but am unsure on what to use?
Old Oct 27, 2014 | 08:54 PM
tspeed109's Avatar
tspeed109
http://www.ebay.com/itm/NEW-OEM-DODGE-CHRYSLER-JEEP-MOPAR-set-of-Drain-fill-plugs-/161442667425?pt=Motors_Car_Truck_Parts_Accessories&hash=item2596bb9ba1
here is my new plugs I ordered hope to get them by friday so I can get this fixed.
Old Oct 27, 2014 | 09:08 PM
Tom A's Avatar
Tom A
Section Moderator
I had the same problem on another truck (not my Dakota), but the placement of the crossmember made drilling impossible. So, I looked up the fluid capacity and added that much fluid through the VSS hole. Not a permanent fix, and no good if you have to top off a leaker, but it got me through in a pinch.
Old Oct 27, 2014 | 09:57 PM
Get any easy out kit. They come with different sizes and instructions on what size hole to drill for whichever size you want to use. I would suggest to start with the smallest size hole and go from there
