Which water pump do I need?
Old Nov 3, 2014 | 03:36 PM
MaximRecoil's Avatar
MaximRecoil
Originally Posted by 01SilverCC
I still say get the OEM Mopar inlet tube. I tried making the one that came with my water pump work but it still pulled the tube too far over toward the engine and that caused the o-ring to not seal completely which resulted in a big leak and a huge mess. If your buddy can fab up something that works but does not cause a leak then I guess it is ok. I think I paid $32.00 for my tube with a "discount" at the dealer but it fit perfectly and worked fine right out of the box so it was worth it to me.
What I would see if I could do to make it work is add something to extend/reposition the bracket itself, without moving the tube. But either way, after I posted my previous post, I looked on eBay, and found a new Mopar inlet tube (part number 55036160) for $23.75, free shipping. I Also found a new Mopar water pump (number 53021018AD) for $63.55, shipped; total cost: $87.30.
By comparison, the dealership price is $41.95 for the inlet tube and $98.35 for the water pump, $140.30 total, not including shipping and/or tax (if bought locally).
My local parts store prices are about $50 for the water pump and about $15 for the inlet tube (aftermarket in both cases, of course).
Old Nov 3, 2014 | 09:50 PM
01SilverCC's Avatar
01SilverCC
Not bad..those should work just fine. Good luck with it and let us know how it turns out.
Jimmy
Old Nov 7, 2014 | 08:14 PM
MaximRecoil
I just finished installing the water pump; no issues with either the water pump or the inlet tube. I did notice another issue though. My heater controls aren't working right, i.e., it doesn't always switch from e.g., defrost to the floor or whatever when you turn the ****. Eventually it decided to switch to defrost, where I intend to leave it, because that's the most important setting.
Old Nov 7, 2014 | 09:21 PM
00DakDan's Avatar
00DakDan
Section Moderator
It sounds like a vacuum issue.
The doors default to defrost when there is no vacuum - for safety. It uses vacuum to shift the doors to the other positions.
Check the vacuum check valve, you'll find it in the vacuum line near the brake booster.
The control head can fail, the part in the dash too. It's really just a valve.
Old Nov 7, 2014 | 09:29 PM
magnethead's Avatar
magnethead
did 00/01+ stay vacuum? i thought it was 100% electrical.
Old Nov 8, 2014 | 09:16 AM
00DakDan's Avatar
00DakDan
Section Moderator
'00 was vacuum, '01+ electrical.
I misread the year of his truck.
Could be a bad actuator or it needs to be recalibrated.
Old Nov 9, 2014 | 12:11 PM
Tom A's Avatar
Tom A
Section Moderator
I would choose a quality remanufactured clutch over a cheap Chinese new one any day. The amount of material removed from the pressure plate is miniscule and will not cause warping. I've installed literally hundreds of remanufactured clutches (mostly in heavy-duty trucks) and can't remember ever having an issue.
Clutch chatter, in my experience, is usually caused by a bad pilot bearing/bushing or damage from overheating (excessive slippage).
Old Nov 9, 2014 | 05:46 PM
MaximRecoil
If the clutch chatter in my truck were caused by a bad pilot bearing/bushing or damage from overheating, would it go away when the drivetrain is warmed up? In my case, the chatter isn't just reduced when the drivetrain warms up, but rather, it disappears entirely, making the clutch engagement perfectly smooth, like on a brand new truck.
Old Nov 9, 2014 | 05:59 PM
Tom A's Avatar
Tom A
Section Moderator
Yeah, that's what makes your case kinda strange. I really don't have an answer.
Old Nov 11, 2014 | 01:49 PM
98DAKAZ's Avatar
98DAKAZ
I cant remember but I think my chatter quieted down after it warmed up also but chatter would still pop up at times depending on how hard I accelerated from a stop.
As I said popped in an all new clutch not rebuilt and all problems vanished.
I would never get a rebuilt clutch why chance it at the cost of having it redone at a later time its not worth it. Usually the shop will never admit its their rebuilt clutch job that's the problem and not try and fix it so you are stuck with the chatter.
