Transmission
Old Dec 15, 2014 | 08:50 AM
00DakDan's Avatar
00DakDan
Section Moderator
Originally Posted by dodgedakotaslt
No the P0750 was the only code I was able 2 see. But to replace it would I just need 2 drop the transmission pan
And remove the valve body.
Old Dec 15, 2014 | 10:28 AM
dodgedakotaslt's Avatar
dodgedakotaslt
Ok if remove the valve body do i need 2 replace that or can i still use it and just replace the solenoid and from wat i been reading wats the other solenoid inside the transmission
Old Dec 15, 2014 | 01:10 PM
00DakDan's Avatar
00DakDan
Section Moderator
There's actually 6 solenoids in the transmission.
You can reuse the valve body.
Do you have a shop manual? If not, go here: https://dodgeforum.com/forum/2nd-gen...-download.html
Old Dec 15, 2014 | 02:47 PM
dodgedakotaslt
Beside the shift solenoid wat r the other solenoids
Old Dec 15, 2014 | 03:46 PM
00DakDan's Avatar
00DakDan
Section Moderator
There are 6 solenoids that work the transmission and torque converter clutches, not just one.
