I need to flush out the heater core in my 98 Dakota.
What is the direction of flow through the heater core ?
Which hose is the IN/OUT ?
TIA
TIA
Quote:
ok, Thank you Sir! Originally Posted by 00DakDan
The "IN" hose is the one the comes from your intake manifold. The "OUT" goes to your water pump.
Dodgevity
close
- Join DateOct 2013
- LocationAtlanta
Liked:449 Times in 401 Posts
TIA
Doesn't matter, you flush in both directions. Flush and more importantly, back flush. Don't go too high with the water pressure.Originally Posted by Katmandu
I need to flush out the heater core in my 98 Dakota.What is the direction of flow through the heater core ?
TIA
Strange I've never had a heater clog up or anyone I know of out west must be a back east problem. Strange as I don't use the heater much so you would think I would have the problem.
Quote:
it's not the use that makes it plugged- it's constantly flowing even with AC on- it's sediment and debris from the rest of the cooling system that gets stuck in the heater core and clogs the flow of water.Originally Posted by 98DAKAZ
Dodgevity
close
- Join DateOct 2013
- LocationAtlanta
Quote:
Mostly, it clogs when people mix coolants that should not be mixed, or use water with minerals vs distilled.Originally Posted by magnethead
Quote:
ie TAP or WELL water. Shops do it ALL the time. Perhaps that's how they get more work. Originally Posted by Dodgevity
Mostly, it clogs when people ..... use water with minerals vs distilled.
Funny I have always used just tap water never been a problem.
I'm a fanatic about Upkeep though change out my antifreeze every 3 or 4 years and run cleaner through the system also.
