No brake pressure
Old Jan 8, 2015 | 07:10 AM
Burico's Avatar
Burico
Default No brake pressure
my son put in steering fluid instead of brake fluid. I found out two weeks later when peddle slipping. flushed all the system twice and it ran for a month, now no brake action. peddle to the floor and barely stops. replaced master cylinder and power booster. don't think caliper replacement would do any good. checked no oil leak. what to do next, any suggestion....Please help.
2004 Dakota, Auto, 3.7L, 2WD
Old Jan 8, 2015 | 09:01 AM
00DakDan's Avatar
00DakDan
Section Moderator
Everything needs to be replaced, except for the steel lines. All the rubber brake hoses, the calipers, wheel cylinders, hydraulic control unit (pump and valves), proportioning valve, everything. If it has rubber in it, replace it.
The power booster wouldn't be affected, it doesn't contact brake fluid at all.
Change everything else. There is no way around it.
Old Jan 8, 2015 | 07:28 PM
magnethead's Avatar
magnethead
I didn't realize that power steering fluid was that much different. dang. Costly "oops".
Old Jan 8, 2015 | 09:03 PM
00DakDan's Avatar
00DakDan
Section Moderator
Brake fluid is alcohol based, PS fluid is oil based. It will damage the seals.
Old Jan 8, 2015 | 09:30 PM
magnethead's Avatar
magnethead
gotcha
Old Jan 9, 2015 | 12:06 PM
Burico's Avatar
Burico
Thanks a lot, calipers ,wheel cylinders and P.valve replaced. ok now, I hope to stay lucky. couldn't find control unit in Dubai yet.
Appreciate the valuable info.
Old Jan 9, 2015 | 12:30 PM
00DakDan's Avatar
00DakDan
Section Moderator
Don't forget the flexible hoses to each front wheel and the rear!
Old Jan 9, 2015 | 08:35 PM
Tom A's Avatar
Tom A
Section Moderator
I've had to fix a truck that somebody did that to once. It wasn't pretty.
