More Questions about SAS
Old Jan 11, 2015 | 06:59 PM
Tom A's Avatar
Tom A
Section Moderator
6" blocks are a totally different story.
Old Jan 11, 2015 | 10:10 PM
HillBillE's Avatar
HillBillE
Yeppers.
When you get into over a 4" lift with small/medium rigs, and over 6" with full size,
you are better off looking into a 4 link set up and coil overs, oe even 4 link and coil springs and long travel shocks.
The ride and articulation really suffer with taller lift leaf springs.
Old Jan 11, 2015 | 10:51 PM
jmasselli22's Avatar
jmasselli22
i already have 2 inch blocks in the back, so a shackle flip will get it up to about 6 inches?
Old Jan 11, 2015 | 10:54 PM
jmasselli22
and should i do leafs in the front or coil springs? which is easier and which will provide a smoother ride?
Old Jan 12, 2015 | 09:04 PM
Tom A's Avatar
Tom A
Section Moderator
Yup.
Leaf springs are much easier, but will ride a little rougher. Probably the easiest way is to use a Ford front end with the factory radius arms and fab some coil spring mounts, but that won't be the best for flex.
Old Jan 15, 2015 | 09:32 PM
jmasselli22
how much harder would it be to use a waggy front end. can i use an '80 waggy front axle?
Old Jan 15, 2015 | 10:03 PM
Tom A's Avatar
Tom A
Section Moderator
It's still pretty easy. You just have to make some kind of a front crossmember for the leaf spring hangers and figure out the shackles for the rear of the springs.
I'm not a waggy expert, so I'm not familiar with the specifics of different years, but if it has a left side pumpkin and no central axle disconnect or anything, it should work. My axle came from an '83 J10 pickup, if that helps.
Old Jan 15, 2015 | 10:06 PM
jmasselli22
What truck is your axle out of?
And what is a crossmember what is its purpose?
Also, an axle disconnect?
Old Jan 15, 2015 | 10:18 PM
jmasselli22
and i like that bumper where'd you get it? haha
Old Jan 16, 2015 | 12:06 AM
Tom A's Avatar
Tom A
Section Moderator
Mine is from a Jeep J10 Pickup truck.
The crossmember is a structural piece that holds the stationary end of the leaf springs.
Some front axles have a 2-piece shaft on one side with a mechanism to connect and disconnect it. They're often found on vehicles that can shift into 4x4 "on the fly" and they are not nearly as desirable as axles with locking hubs. You can see them on these axles.
Thanks! I made it myself.
