Catalytic converter replacement??
Old Feb 13, 2015 | 09:31 AM
jondakotaguy's Avatar
jondakotaguy
Dont feel bad.. mine lasted about 20K magnaflow its still working i can tell by the smell but i got the efficiency code.. i tab with my fist on the casing and it sounds like i can hear the core bouncing a little like the packing came undone..
I have the 5.2L though and im having my plate and gasket fixed.. incase that is what caused it but the cat is not clogged though that we can tell lol.
So i know your pain and frustration.
Old Feb 14, 2015 | 06:12 AM
tspeed109's Avatar
tspeed109
Default oxygen sensor holes
Just got my catalytit converter ready to install but the threads are stripped and i cannot get oxygen sensor threaded in.
How do i fix this or do i just send it back for a replacement.
Thanks
Old Feb 14, 2015 | 07:45 AM
If it is brand new, send it back. Or, re thread it.
Old Feb 14, 2015 | 09:27 AM
00DakDan's Avatar
00DakDan
Section Moderator
/\ This.
It's not a Bosch O2 sensor is it?
Old Feb 17, 2015 | 12:32 AM
magnethead's Avatar
magnethead
Use only an NTK sensor and only copper core plugs, autolite 3923 . Anything else and you'll be wasting money, time, and chasing your tail making the CEL go away.
Sounds like you have a clogged cat and possibyly a fuel pressure issue?
Old Feb 17, 2015 | 06:10 PM
jondakotaguy
IDK about those 3923's ... I tried them in my 318 and it was really smooth idle for like the first few miles.. but was like the truck got castrated.. put back the copper core autolites for the engine and ran good again.
