In out tie rod ends
Feb 12, 2015 | 08:05 PM
In out tie rod ends
Should I do the Inners with the outers? Or maybe they've already been changed?
Feb 12, 2015 | 08:16 PM
I moved this into a new thread Shufly. It just makes it easier for all of us.
I'd only change what needs to be changed. If the inners are OK, and they usually last longer than the others, leave them be.
Feb 12, 2015 | 08:29 PM
This^^. If get are ok, no play, etc. probably ok.
Feb 12, 2015 | 11:25 PM
where can one get the outers? O'R doesnt show them
Feb 13, 2015 | 07:33 AM
Quote:
Originally Posted by
magnethead
Not sure what O'R is but Rock Auto has them.
Feb 13, 2015 | 09:45 AM
Feb 13, 2015 | 09:21 PM
00DakDan
thanks. I need the inners then, that go into the ball coupling on the rack....said coupling is loose.
Feb 13, 2015 | 10:31 PM
Oh. Sorry. You said outers.
Feb 13, 2015 | 11:07 PM
I was thinking inner as being rack side and outer as the end side, with the tie rod ends seperate. I was wrong.
