need help with transmission
Old Feb 28, 2015 | 12:50 PM
dodgedakotaslt's Avatar
dodgedakotaslt
Default need help with transmission
Hey there i need with figuring out wats wrong with my tranny i thought it was the shift solenoid and replaced it but still cant get my truck 2 move even inch forwards or backwards in any gear so wat do i need 2 do or do i have 2 get the solenoid programmed to or wat
Old Feb 28, 2015 | 02:51 PM
00DakDan's Avatar
00DakDan
Section Moderator
Was it moving before you replaced the shift solenoid?
I'm assuming you changed both filters and the fluid. Did you use MOPAR filters? There are a lot of crappy replacements out there that don't seal. In that case you'll pick up air instead of ATF and you won't move - period.
Old Feb 28, 2015 | 04:23 PM
dodgedakotaslt
yup everything I replaced was with mopar parts and fluid. no it wasn't moving at all before or after. I can put the truck in any gear and put my foot on the gas and all that is happening is revving of the engine.
Old Feb 28, 2015 | 07:29 PM
00DakDan's Avatar
00DakDan
Section Moderator
You might want to start by checking the hydraulic pressure - with a mechanical gauge.
Old Feb 28, 2015 | 08:05 PM
dodgedakotaslt
wats the low/reverse solenoid and wheres that located cuz im looking up code P0750 cuz I just replaced the solenoid on the valve body but that didn't fix my problem
Old Feb 28, 2015 | 08:48 PM
00DakDan's Avatar
00DakDan
Section Moderator
The L/R solenoid activates the L/R clutch
It's located in the solenoid and pressure switch assembly.
Old Mar 1, 2015 | 03:57 PM
dodgedakotaslt
after doin some research could it be the line pressure sensor that went bad
Old Mar 1, 2015 | 04:04 PM
00DakDan's Avatar
00DakDan
Section Moderator
You won't know until you check the pressure.
Old Mar 1, 2015 | 04:16 PM
dodgedakotaslt
ok how and wat do I need 2 check the pressure
Old Mar 1, 2015 | 05:56 PM
00DakDan's Avatar
00DakDan
Section Moderator
There are two ports on the RH side of the transmission case. You need a gauge that goes to 300 psi. You can check the line pressure sensor if you have a DRB or another scanner that can connect to the transmission.
The sensor just measures pressure. If you have a pump failure or internal leak you aren't going to move - period. Check the pressure before throwing more parts at it.
