Just sharing my plennum fix so far.. PIC HEAVY
Old 03-04-2015, 11:10 PM
jondakotaguy's Avatar
jondakotaguy
jondakotaguy is offline
Default Just sharing my plennum fix so far.. PIC HEAVY
So I'm in the process of doing the plenum fix and timing chain upgrade.. doing a little every evening after work..
so far its been really smooth sailing.. every bolt about came off like super lubed with KY Jelly or something.. i have had no issues.. Not sure if that just means someone was in here recently before i got the truck 4 years ago or more or if the engine has just been really taken care of.
she's got 157K on the OD. cant really see any blown seals yet.. everything looks intact.. but it does look like the intake seals are pretty bad off...
Only thing that really stuck out to me was the carbon build up on the valves.. looks like I need to do some de-carbon job on them..
For 157K on OD i don think they are that bad off.. i expected worse..
Any of your experienced guys wanna look through these pics and point out anything I'm overlooking that needs my attention feel free
Old 03-05-2015, 04:29 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Looking at Pic #2 your lifters look kind of dry can you post a clearer bigger Pic of a few lifters that whole area looks dry?
Old 03-05-2015, 07:32 AM
Dodgevity's Avatar
Dodgevity
Dodgevity is offline
Not familiar with the 5.2 or the plenum fix. What is the problem with it? Looking forward to seeing how your chain is. I've got 253K on this 4.7 and I know it was run low on oil at one point. Maybe not till the light turned on but low, nevertheless. I'm already past the point of suggested chain replacement. I hear no weird sounds or any problems that suggest the chain is going.
Old 03-05-2015, 08:09 AM
jkeaton is offline
Dodge Forum Administrator
4.7 did not have the plenum issue. Only the LA engines, V6 and both V8's. Something about them using dissimilar metals for the intake plenum and belly pan and it would warp, causing a huge vacuum leak, sucking oil into the intake, fouling #8 cylinder, plugging the cat and cracking the block.
You can read about it in the plenum sticky in the 2nd gen Ram section,
Old 03-05-2015, 09:45 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
You may want to use an engine flush or a thinner strong cleaning oil for 2 oil changes to get the little sludge you have out.
Old 03-05-2015, 10:42 AM
jondakotaguy
Thanks Dak; I've got a fair amount of pooling there in the center but honestly I've been kinda running around just putting fresh oil in for a bit.. truck mainly sits in the drive way and there was a time when i was looking at other options i was well lets say letting her go.. but I suspect someone using cheap *** oil and gas in here before i even got her..
So now i'm up and roaring to get her fixed and do some things to her so Ill be taking better care of her oil change wise. LOL.
Old 03-05-2015, 10:45 AM
jondakotaguy
I seen a job on that engine with the OHC setup it has and it looked like a mess.. lol.
No I'll stick to my good ol weak underpowered American engine lol ha ha
Old 03-05-2015, 01:54 PM
Dodgevity's Avatar
Dodgevity
LOL, lemme guess, you think Diamler had input on the 4.7 design. Nope, it was all Chrysler. Not that it makes it any easier.
Old 03-05-2015, 04:53 PM
jondakotaguy
LOL Still a german designed engine.. just like new dodges are Fiat..
GM is government motors...
HAHA..
On a serious note though i checked the back of the plennum and there was a hell of an oil leak i never knew about back there from the gasket..
RTV ok on for the front and back of the main assembly right like an old ford? the hughes guide says no to the other gaskets.
Old 03-08-2015, 01:34 AM
jondakotaguy
OK been busy the last couple of days busting it down got around to pulling the balancer and got a full days worth of work done.. got it done and back together actually.
Upgraded the chain to double roller old one was deft. on its way out..
Plennum leak:
Old Chain:
SLOP:
New chain set in:and buddy brought the coors.. so had to drink it lol
New plate installed:
Back together finally... I'm tired.. I need more beer.
Quick Reply: Just sharing my plennum fix so far.. PIC HEAVY
