1997 dodge dakota need help missfire
Old Mar 12, 2015 | 12:03 PM
jws123's Avatar
jws123
Default 1997 dodge dakota need help missfire
I picked up a 1997 dodge dakota 3.9 with 180k and it has a random missfire code p1391
It is running like **** sounds like its running on 3 cylinders backfires threw the intake when u give it gas sometimes The guy i got it from said he changed the
Coil,crank position sensor,cam sensor,distributor,map sensor, and a new Computer and a ton of other things what else could do this i have looked around it is a common issue but cant seam to find anything.
Old Mar 12, 2015 | 12:17 PM
I dont see plugs or wires listed as being changed. Wats the condition of those items?
Old Mar 12, 2015 | 12:57 PM
jws123's Avatar
jws123
Yea the plugs wires rotor and cap where all replaced compression is good aswell
Old Mar 12, 2015 | 01:00 PM
jws123's Avatar
jws123
What is the fuel pressure suppose to be? i dont have a manual for it yet
Old Mar 12, 2015 | 04:19 PM
jws123's Avatar
jws123
Another thing i noticed is the rpms gauge does not work other ones do tho on another car i remember it was connected to the crank sensor and cam sensor so could that mean one is bad if its the same on dodge?
Old Mar 12, 2015 | 05:39 PM
00DakDan's Avatar
00DakDan
Section Moderator
The fuel pressure should be about 49 psi.
The tach runs of the PCM.
Old Mar 12, 2015 | 05:55 PM
jws123's Avatar
jws123
He gave me the old pmc plugged it in still no rpms gauge even with the new one still doesn't work i think this is somehow connected with it not running right will have to dig into it more tomorrow.
also the guy replaced the whole distributor how do i know if he put it back in the right spot or not is there a way to check? also want to check the timing chain how are the marks suppose to line up?
Old Mar 12, 2015 | 06:22 PM
00DakDan's Avatar
00DakDan
Section Moderator
He pulled the distributor and screwed up the fuel sync. That's why it's running poorly. Let your dealer reset it with a scan tool. It's the easiest and fastest way.
P1391 is not a random misfire code, it's a loss of cam or crank position sensor.
Make sure that OEM Dodge sensor have been used. Lots of the aftermarket ones are garbage.
Old Mar 12, 2015 | 06:39 PM
jws123's Avatar
jws123
will check the crank sensor and surprisingly i dont have any dodge dealers near me is there
any other way to do this?
Old Mar 12, 2015 | 07:09 PM
00DakDan's Avatar
00DakDan
Section Moderator
You need a really good quality scanner to set it. A good shop should have it.
Not a code reader, a scanner. It's reading live data to set it.
