Manual transmission questions
Old Mar 17, 2015 | 03:03 PM
93 ragtop's Avatar
93 ragtop
Default Manual transmission questions
I am trying to locate a nv3500 transmission (4wd) for a project. Can you tell me if the v6 and v8 Dakotas both used the nv3500 or was it the v8 only. Also, does anyone know what years used this transmission. Thanks for your help.
Edit to add, I know that the earlier Dakotas (87-96) used the nv2500 or equivalent transmission in the v6 but the 94-96 v8 got the nv3500. Really just trying to clarify what manual transmission the v6 97 and up used.
Old Mar 17, 2015 | 06:32 PM
00DakDan's Avatar
00DakDan
Section Moderator
In '00 and up the V6 used the NV3500.
I "think" the 98-99 V6 used the AX-15.
Old Mar 18, 2015 | 08:22 AM
93 ragtop's Avatar
93 ragtop
Thanks for the reply. Do you know if the 2000 version is basically the same as the earlier ones? ie, spline count, etc. Hopefully it is and that will open up the market a little more for whats available.
Old Mar 19, 2015 | 05:17 PM
theJester517's Avatar
theJester517
I have a 97 v6 and it has a AX15 transmission. I think the NV2500 and 3500 were saved for the v8s.
Old Mar 19, 2015 | 05:59 PM
00DakDan's Avatar
00DakDan
Section Moderator
I don't know the answer on the spline counts.
Old Mar 21, 2015 | 11:03 AM
93 ragtop's Avatar
93 ragtop
Actually I believe the AX15 was supposed to be an improved version or equivalent of the NV2500. They were used in the v6 trucks like mine (87 4wd) The NV3500 is considered a med. duty transmission and was used in V8 apps. at least in the first gen. Dakotas.
Old Mar 21, 2015 | 11:07 AM
93 ragtop's Avatar
93 ragtop
I will try to find out if it is the same. If so, I believe you have given me a larger vehicle selection to look at!! So far, the only real difference I have found is the 97 and up, have finer teeth in the transmission along with different synchronizers. Supposed to make them quieter and shift better. Thanks again for your help.
Old Mar 21, 2015 | 02:48 PM
theJester517
I have a 97 service manual if you want me to take a look
Old Mar 25, 2015 | 08:12 AM
93 ragtop's Avatar
93 ragtop
Thanks for the offer, but there is a guy (ragged89) who swapped a nv3500 out of a 97 into his 89. He has said it was 23 spline just like his orig. trans was. Basically said everything went smooth. The only difference is the nv3500 is about 5/8 in shorter then the orig. transmission in his 89.
Old Mar 27, 2015 | 08:26 AM
magnethead's Avatar
magnethead
My boss might know how many versions of the 3500 exist. What are you transplanting to? If you're working on a YJ, he might know exactly where to dig up compatible units.
Also, there is this-
http://en.wikipedia.org/wiki/New_Venture_Gear_3500_transmission
All 5 of these transmissions can be interchanged as a complete unit with the following caveats.
"Drop in" interchanges between GM S (S10 etc.) and C/K trucks will require modification of driveshaft length and crossmember placement. GM S models have a longer tail-shaft than C/K trucks.
Master & slave cylinder bore sizes went from standard to metric in 1992 (Master: 11/16"->18mm, Slave 13/16" ->20mm)
GM and Dodge transmissions will not interchange.
The case and bellhousing are one piece with differing, engine specific, bellhousing bolt patterns.
Dodge uses Dodge specific input shaft length, spline count, and pilot diameter.
Dodge output spline count differs from the GM units.
