2000 4.7 Turns Over but wont start
Old Mar 23, 2015 | 12:14 PM
smonty46's Avatar
smonty46
Default 2000 4.7 Turns Over but wont start
My 2000 Dakota 4.7 cranks but wont start. My cheap code reader shows "linking error". Odometer window show "nobus" . I replaced the PCM and nothing changed. No spark. Noticed that my rear 02 sensor is clicking and getting warm when I turn the ignition to on position. Also, my fuel gauge quit working. Don't want to change fuel pump out as there is no spark anyway. Anyone have any ideas before I start spending $ at dealership that I cannot afford. Thanks!
Old Mar 23, 2015 | 12:21 PM
archemedes74's Avatar
archemedes74
a little research says no bus is a bad cluster
Old Mar 23, 2015 | 12:24 PM
smonty46's Avatar
smonty46
Thanks for the info. Will read up on bad cluster probs.
Old Mar 23, 2015 | 04:40 PM
00DakDan's Avatar
00DakDan
Section Moderator
No bus means the cluster isn't talking to the CCD bus. It may be a bad cluster but more likely it is something killing the CCD bus. It could be any of the modules, ABS, airbag, CTM, etc.
The fuel gauge is driven off of the PCM, all the gauges are. Was it dead before the "no start?"
Check for 5 volts to the cam and crank sensors, the orange wire, pin 3 is the +. If they short out they can take down the PCM.
Old Mar 23, 2015 | 09:12 PM
smonty46's Avatar
smonty46
Thanks Dan. The fuel gauge worked before the no start situation happened.
Old Mar 24, 2015 | 04:33 PM
00DakDan's Avatar
00DakDan
Section Moderator
I'd start with the cam/crank sensors. "No bus" problems can be a PIA to chase down.
