Electrical Issues
Old Mar 28, 2015 | 12:34 PM
dan0614's Avatar
dan0614
Default Electrical Issues
Hi, I have a 2002 Dakota, V6 4x4 5-Speed manual and the other day some of the electrics stopped working.
The Radio, Controls for the Heat and A/C, and the 4 wheel drive switch stopped working.
If the headlights are off, the service 4 wheel drive light randomly flashes on and off while driving, if the headlights are on the service 4 wheel drive light stays on.
Any thoughts on what might be wrong?
Old Mar 28, 2015 | 01:33 PM
00DakDan's Avatar
00DakDan
Section Moderator
I think you have a bad ground.
The radio, HVAC controls, CTM, and the transfer case use the same ground - G207.
It's located by the airbag control module, lower center of the instrument panel.
If you follow the harness you'll see it split off with two separate grounds. The one most forward is G207. Make sure they are both clean and tight.
Disconnect the battery before you remove the ground.
Old Mar 29, 2015 | 05:13 PM
dan0614's Avatar
dan0614
Thanks for the response, A friend recommended that I reset the CTM by unplugging it and removing the negative battery terminal for 10-15 minutes. I did this and it fixed the issue.
