04 dakota
Old May 18, 2015 | 02:28 PM
AndrewMorin's Avatar
AndrewMorin
Default 04 dakota
I have a 2004 4.7L V8 awd dakota and the front end is making a weird noise. it almost sounds like keys jinging. its like a higher pitch rattle and it only makes that noise when i let off the gas. once i press on the gas it goes away. it never did that until i took the front end apart to change the oil pan. anyone know what could be making that noise?
Old May 18, 2015 | 04:33 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum Andrew.
Front prop shaft? High pitched would be a bit unusual for that though. Try it with the t-case in "lock" and see if it changes.
Old May 18, 2015 | 05:24 PM
AndrewMorin
its not a high pitch rattle more like a regular rattle but it only does it once i get it higher than 20km/h and it goes away and i press on the gas then comes back when i let off. had to drop the whole front end just to get the oil pan so maybe when it was put back together something was put in wrong?
Old May 18, 2015 | 06:23 PM
00DakDan's Avatar
00DakDan
Section Moderator
Exhaust? Maybe a heat shield?
Old May 25, 2015 | 09:21 AM
AndrewMorin
figured out the problem. it was the U-Joint. quick $30 fix and now she`s running good. it was the front end shaft
Old May 25, 2015 | 04:07 PM
00DakDan's Avatar
00DakDan
Section Moderator
Glad it was an inexpensive fix. Thanks for posting back.
