ABS light and Brake light
Old Oct 16, 2015 | 07:16 PM
Chris Flue's Avatar
Chris Flue
Default ABS light and Brake light
First post here.
2004 Dakota 4.7
Sometimes both the ABS and the brake light comes on. I've gotten a code once before about low brake fluid.
The fluid is full and it's a new master cylinder with a new fluid sensor.
I tested the pigtail and I'm getting 5v reference.
I've unplugged the sensor and the lights stay on.
Do you think it's a bad switch? It's new. But it is aftermarket.
Old Oct 17, 2015 | 01:24 AM
Chris Flue's Avatar
Chris Flue
I guess I'd also like to pint out sometime when I start my truck there is no lights. Like normal. Sometimes I'll start and the lights stay on. But if I turn off my truck and restart the light will stay off.
Old Oct 17, 2015 | 09:17 AM
00DakDan's Avatar
00DakDan
Section Moderator
The system is supposed to "self-test" at start and if it detects a fault it trips the ABS light.
You may need to have the code read. If the ABS light is on there should be one stored.
You need a scanner that can read brake codes to do that.
Old Oct 17, 2015 | 12:26 PM
Chris Flue's Avatar
Chris Flue
Well like I said. I get a low fluid code. But the reservoir is full
Old Oct 18, 2015 | 01:43 PM
magnethead's Avatar
magnethead
Which ABS do you have, 4 wheel or rWAL (rear only)? On RWAL, there is a sensor on the RWAL/proportioning valve. Has a 4 wire connector for the solenoids and the sensor. You may have a faulty RWAL module if so equipped.
Old Oct 18, 2015 | 03:10 PM
00DakDan's Avatar
00DakDan
Section Moderator
What code are you getting? How? Via a scanner?
I'd still pull the ABS codes.
Old Oct 30, 2015 | 09:15 PM
ozzie banana's Avatar
ozzie banana
I have a 1999 2 wheel drive, auto trans. Both the ABS and Brake lights come on. If I turn the ignition key to start, but not far enough to engage the starter, after a second, they both go out, and stay off. Strange, but it works. Just my two cents.
Oz
Old Oct 30, 2015 | 09:28 PM
00DakDan's Avatar
00DakDan
Section Moderator
That's normal Oz. The ABS system self tests at start up.
Old Oct 30, 2015 | 09:35 PM
ozzie banana
What I meant was that I do this while going down the road, while the engine is running.
Old Oct 31, 2015 | 02:40 AM
98DAKAZ's Avatar
98DAKAZ
My 98 Dakota started doing this about 6 months ago start her up and go abs and brake dash warning light stays on.
I found if I pull over shut down wait around 5 to 10 seconds start back up everything is ok no dash warning lights. Dosent always happen sometimes for months its on off.
Im guessing abs/speed sensor on rear Diff is sticking going bad
