Starting the build process
#311
FlowKooler water pump arrived yesterday. It's a GMB generic pump housing, but they make and install a billet impeller rated for +30% flow. Because the block is half-filled, water volume is reduced, and I'm also looking at using a smaller radiator to make room for the intercooler. Thus, the water pump will be working overtime.
Got the aluminum spacer block drilled this morning. Still need to take a chunk out of it to clear the power steering pump, weld up the strut, and get the coolant bypass hose and fitting. Slowly but steadily getting closer. MAP sensor and pigtail is installed, TPS pigtail is installed.
Only thing really left to sort out is crankcase evac.
https://photos.app.goo.gl/Qc3MmunbKDLHRDDx8
https://photos.app.goo.gl/79DT3yo38Wb6zkg4A
https://photos.app.goo.gl/y4ox3WewAw6kjCBv7
https://photos.app.goo.gl/LdJUvQZZSf1qnFKbA
https://photos.app.goo.gl/XCUStvEPX9z6vixaA
https://photos.app.goo.gl/1tev6rbLbgzpdCFh8
https://photos.app.goo.gl/sAKMGC9DKnz3mxv17
https://photos.app.goo.gl/CHY37Q3wDgLwfy6u8
https://photos.app.goo.gl/L1p3u9THXTKpUShV7
https://photos.app.goo.gl/nrPGc15nppKpydnf8
https://photos.app.goo.gl/2NdgbCoYyCwG4pZ77
https://photos.app.goo.gl/YWsxwTRBPpZaRufu9
https://photos.app.goo.gl/jirMNZfSaLXf1tov8
https://photos.app.goo.gl/SamrRf3Rc91PDVYs9
https://photos.app.goo.gl/tz2gFoXBdN9Wpjmz9
https://photos.app.goo.gl/9GjHkZ3oPWaVduTt5
https://photos.app.goo.gl/8zrPJ4LdKZHPkd4X8
#312
A couple things going on here -
I might have a solution for Crankcase evac. I found a company that makes combination pulleys for Alternators. This would allow me to mount a vacuum pump outboard of the alternator, and use something like a 24 or 30" V-belt to drive it off the alternator. https://www.cuoffroad.com/product-li...ss-components/
Everything goes together nice and kindly, but the power steering pressure hose is kind of arguing with the water pump over space. Not sure if a crimped 120 can be done, but that is what it looks like it will take.
Scott Batiste is doing a similar FMIC setup to what I plan. Only difference is being a 99, his radiator is behind the core support, allowing the intercooler to reside inside it, allowing for a bigger FMIC. Mine being an 01, plus having 2.5" of pulley hanging out there, I have moved the bumper out 2" to hopefully fit a 3.5" FMIC in front of the core support, a 3" radiator inside the core support, and a 1" condensor somewhere between them. Main issue will be grille clearance.
https://photos.app.goo.gl/EDgK37HMxCN1s1qT6
https://photos.app.goo.gl/sXpppxtqXFjWNoF78
https://photos.app.goo.gl/scf68kGfNqFJSWiLA
https://photos.app.goo.gl/5C9JfVW9tkg1yM1f8
https://lh3.googleusercontent.com/J_...k=w462-h820-no
https://photos.app.goo.gl/kMBBWsk8DYRJTxuv7
https://photos.app.goo.gl/Q9KwxnuyowtVb6kQ7
https://photos.app.goo.gl/cfhZ4yCTs4pCc8DXA
https://photos.app.goo.gl/uyCVMuQ6DXDxcr2h6
https://photos.app.goo.gl/eCM56xEn3MHqiMXV8
https://photos.app.goo.gl/gSif8ebzbn3KJmYk7
#313
I'm not gonna call it a super productive weekend, but I did make some forward progress.
https://photos.app.goo.gl/eEdwWnvJUEGkS8KN8
https://photos.app.goo.gl/qk2ivu8s2spN9adQ7
https://photos.app.goo.gl/vP2Too4W2L9tq7EP9
https://photos.app.goo.gl/28NWVBbFVqrNwETs7
https://photos.app.goo.gl/9iVp2BAfPpXxTx6u5
https://photos.app.goo.gl/igf7BgGzjRaHGJkY9
https://photos.app.goo.gl/LEpU1nrgnMmkRrTL9
https://photos.app.goo.gl/wxYKKbbnQVa1Jb8u7
https://photos.app.goo.gl/Sv75s3CWpCbtQZ4V8
https://photos.app.goo.gl/XJ8omPg5oVsn4M5K8
https://photos.app.goo.gl/3f26a5FQ12ziGKML9
https://photos.app.goo.gl/JEAjspixyJnUUcZQA
https://photos.app.goo.gl/ndqwFVm98VRiuwuP7
https://photos.app.goo.gl/LivN9oAGqBctTsKg8
https://photos.app.goo.gl/aeXnYnt5arKLruMn8
https://photos.app.goo.gl/49qjCtZmUR2g7Dyv8
https://photos.app.goo.gl/1uAP8HcjzfFb957c9
https://photos.app.goo.gl/8gGPPekwTApBjKvR9
https://photos.app.goo.gl/fuknTb9pihvKCsz97
https://photos.app.goo.gl/6XdzZbVNrJie4WGM6
https://photos.app.goo.gl/Pp7oMdbXjEsYrZw89
https://photos.app.goo.gl/PXreFc7mmNwXYo3U8
https://photos.app.goo.gl/AvnxTNJjxJP53rWz8
https://photos.app.goo.gl/CHjcFXsv15k1mGQg6
https://photos.app.goo.gl/czsdBprm9AZh2TRH7
#314
Picking up some pieces from the machine shop tomorrow that I dropped off Thursday morning. Hopefully I'll be one step closer to finished.
Raced in Tulsa last week. Photos First:
https://photos.app.goo.gl/q2AF1iANa4eycbnv7
https://photos.app.goo.gl/fJMAsbLw7DSQQcBd7
https://photos.app.goo.gl/ahDiaQnL53rVgzHW8
https://photos.app.goo.gl/sKG5i3V45YbDFJv1A
https://photos.app.goo.gl/xZWxbAHYy2KFnq7A9
https://photos.app.goo.gl/mQZkd4WoPumeL4n9A
https://photos.app.goo.gl/WPM8q7GQGXboEJfq7
https://photos.app.goo.gl/776pc1Hp4SxuNrXj7
https://photos.app.goo.gl/6w14vQabTd4oop476
https://photos.app.goo.gl/wLmPo64K6EWJ4mh46
https://photos.app.goo.gl/VxrCAav5dBFnTjzh6
https://photos.app.goo.gl/jMXQDstPdLyut7tH6
#315
Was in Houston for work on Thursday. Left at 7:30 AM, got home at 10:30 PM, then turned around and left for Tulsa to race at 6AM on Friday.
Our friend Bob Alberty brought his car back out - Twice he's been 1 for one with parts breakage on his first run. Well this time he managed not to break anything until Q4. He's one of those guys that doesn't go easy on things, smoking the tires in the previous 3 qualifiers before laboring it down through to a 3.97 in Q4.
Another friend, Chanse Bullock broke a driveshaft in the lane next to us in Q4. He's lucky it didn't tear more stuff up.
Coming back from Tech Inspection, the rear end started locking up. We barely got it into the pit space when chunks started spitting out from inside the wheels....wheel weights. Turns out the aluminum tape had come loose, and the weight glue delaminated enough for them to droop down and get stuck in the caliper. We ended up super-glueing the weighs back in place, then covering them with gorilla tape to make sure they stay, then aluminum tape to reflect the brake heat. We've had this happen once before, the the brake heat will vaporize regular duct tape - almost caused a fire last time. So now we know better.
Q1 dad had to pedal it once as the car drifted out of the groove, went 3.96 with our NHRA setup in it, was on a 93 run or so, about 5 faster than we'd like.
Q2 was almost midnight, the air temp was 50 degrees and track temp was 72 degrees. [USER=5427]@Nitro Dude[/USER] knows a cold track is bad...but I decided to throw all the timing at it and rotate earth for the hell of it. It stuck with a .959 short time, dad had to pedal twice, out fo the throttle for a full second, and still went 3.90 to put us in the #2 spot.
In Q3 I left that same timing map in it, the 60' slowed to a .980 but was good enough for a 3.88, still #2 to Bob Henry's 3.870.
For Q4, we took some fuel away and threw some timing at it (not a combination you'd normally do) and that was good enough for a 3.870 to tie for pole position - but our 188.4 MPH was not enough to catch Bob's 189.3 MPH.
First round, we ladder up against a guy that lives 10 minutes from us. Nothing like driving 5.5 hours to race your neighbor....and lose by 0.0022 seconds.
https://photos.app.goo.gl/QvUCsqx4CbbRqDKK9
https://photos.app.goo.gl/D4mKSGSUgAiUPeyr7
https://photos.app.goo.gl/EWHoVs5NQg7bUxJB6
https://photos.app.goo.gl/RfHnd4ufXLoxYH516
https://photos.app.goo.gl/AP8rZT9LhHmJqACo7
https://photos.app.goo.gl/XhdnoyMJQeYqaSpB6
https://photos.app.goo.gl/bqPuFw7kADXym6FTA
https://photos.app.goo.gl/mEq3LzqRTjhXcYre9
https://photos.app.goo.gl/RqQAUz4KYMLZezNY8
https://photos.app.goo.gl/HS8tsbHdAHpwd4Fv8
https://photos.app.goo.gl/JQb8TQENi66L7BpX9
https://photos.app.goo.gl/LQuznTVNacxPip7VA
https://photos.app.goo.gl/fGYD51HwoVXP4JwZ9
#316
Hope to have an update on my truck this week...it's been a minute, and I'm waiting on stuff that's getting made at the machine shop.
So after unloading from Tulsa, We found out that the flexplate had come loose.
https://photos.app.goo.gl/SfVcc4sNNh8h5BDD9
https://photos.app.goo.gl/QHd2sqW8Z1SpNq3C8
https://photos.app.goo.gl/G6nDxzYgCWYkmGuM8
https://photos.app.goo.gl/N6n9SdBBBG7KbiFg6
https://photos.app.goo.gl/Wssns9CQz2WsAEz16
https://photos.app.goo.gl/Hz7Kf9cS7t3wu2gi8
https://photos.app.goo.gl/kbbkgkcAJVVKdFVy9
https://photos.app.goo.gl/mfxgHFzhTAZ5w12s6
https://photos.app.goo.gl/fohvfVtRJYN6MnVW7
https://photos.app.goo.gl/oKXtUCAgEBhHPa178
https://photos.app.goo.gl/3nvndJCYcGmFwiLfA
https://photos.app.goo.gl/8TdfrRxm4kJBXKe3A
https://photos.app.goo.gl/s6ahJywN47PZ7UWv7
https://photos.app.goo.gl/zyLgmPDa1joY522w5
https://photos.app.goo.gl/pWvwafDZcUrvF4z79
https://photos.app.goo.gl/cB2zgR6zu3hbp2oq7
https://photos.app.goo.gl/Sh7t14dBddVc2fRV8
#317
More truck updates coming this next 2-weeks off.
I've reached a new level of exhaustion - I think.
Got to the track at Noon on Thursday for testing. First run it dropped a cylinder at the hit and never really cleaned up. Turned out to be a bad spark plug.
Second hit was way slower than we wanted, but the air was miserable.
https://photos.app.goo.gl/bGMBKf5wiLWfpzmF6
https://photos.app.goo.gl/AmMCK1a9zbKqSWWB7
Saw a couple neat cars. The Gary Scelzi "Tribute" car is owned and flown by one of Clay Millican's crew guys.
The Prowler is a 1 of two - the guy custom made the mold himself and has 2 of the bodies from it.
https://photos.app.goo.gl/hzFNmgVqCVuZA69z9
https://photos.app.goo.gl/bjU5bj4esuy6Mjrf9
In Q1 Friday morning, we took the pole out of the gate with a 6.103 on the 6.10 index. Nobody was able to touch it in Q2 or Q3. Back to Back poles for NHRA events.
https://photos.app.goo.gl/BmKihhLePnSdMobN9
https://photos.app.goo.gl/VV9vcnRo27XVpxQz5
https://photos.app.goo.gl/mVkChyae12UK3bTw8
https://photos.app.goo.gl/UutnFjJacVtf9WsL8
First round off the trailer Saturday morning we had a friend of ours here in DFW - AGAIN (3 races, three locals in first round). His nitrous didn't work, so dad shut off and coasted around him for the win. Second round the sun got up in the sky and the air went bad - we were doubting the predictor, but it was right. Luckily the other guy red lit because we were way slow.
https://photos.app.goo.gl/uvnusBT9cNTr1TJL7
Third round is it's own story. All weekend long the track was having clock issues. Unfortunately, it bit our opponent, so they made us re-run the race, even though our opponent was mathematically ineligible.
0.315 light + 6.506 ET = 6.821 total
0.021 light + 6.270 ET = 6.291 total
6.76 dial - 6.27 dial = 0.490 handicap
6.291 total + 0.490 handicap = 6.781 total , for a margin of victory in our favor of 0.040
Using historical incrementals, I was able to determine that we were on a 6.235-6.242 run. We didn't want to slow ours down, so we rolled with it. Our opponent is on nitrous, so we knew they would be turning theirs up.
A small burn-down ensued at the tree, and dad was late. But it didn't matter because they turned their up way too much and went out the back door while dad shut off at the predetermined point, beating them again.
https://photos.app.goo.gl/xgoHHDpRrNmwaCHq8
Once through that hurdle, we had the world champion up next. He didn't make it easy for us, but he left a door open for us to go through. That led us to the #2 qualifier, where dad made a mistake of lifting too early when our opponent lifted and got back on it.
https://photos.app.goo.gl/YyCQPuRo9aHVHYSw5
https://photos.app.goo.gl/yBEVnebpsF8CDjZR8
#318
Finally have my breath long enough (ish) to do a writeup and process photos.
We left the fuel setup from Houston in the car but changed pulleys from a 54 to a 53 to make up for atmospheric losses. Left the same launch control profile in the ignition as well, and went 3.94 off the trailer. A decent hit, quicker than we expected. The track indicated to me that it would hold alot more.
So I fed it alot more in the launch control for Q2. Not quite the kitchen sink, but something that was safe-yet-aggressive. We rolled a little bit of timing into it, and went 3.92. The track had ALOT of grip in it, not enough to upset the tire, but plenty to take a little more.
Several other cars took the launch control all the way out, and subsequently smoked the tires. I threw a lot more at ours, and I wasn't really sure if it would hold or not after watching the smokeshow, but I was confident that it wouldn't smoke the tires. Sure enough, it slowed down a bit on the 60', but the extra wheelspeed picked up at the other end to do 3.90.
We got home around 3AM, I went to bed around 4 and got up at 1. We left the house at 2, got to the track at 3, and did a full service on the car before Q4. I went up and walked the track several times - before any prep was done, after they scraped it, and again after they sprayed. I was really skeptical initially given the 136 degree track temp and softened launch control setting to the Q2 level, but once they scraped and sprayed it, dad and I decided to throw the Q3 setup at it - knowing it would stick in E1 once the sun went down. So I put the Q3 launch control profile in and dad and I both prepared for it to smoke the tires - I moved the over-rev control RPM down from 8400 to 8200 (we launch at 3300 and shift at 8000, with high-limiter of 8600). It definitely slid the tire hard and killed the 60', but at least it stayed hooked up and gave us data.
At that point, E1 was a guessing game. We dialed what it ran in Q2, figuring the air and track were fairly similar. WRONG. Luckily the driver in the other lane red-lit, dad was able to send it out the back door to a 3.90.
And we stuck with that number the rest of the night. Round 2 was fundamentally a Top Alcohol Dragster that was slowed down to get under our 3.66 field cap, running 3.70's - spotting most of the field by over a tenth and 10 MPH. The driver in the other lane, being unable to see over the sidepanels, was going to go out the back door, and dialed what they ran in E1. So dad prepared to drop if she was ahead significantly. It was a close race, dad stayed with it to go dead-on while she went 2 hundredths too fast.
That put us in round 3. We stuck with the 3.90 dial going out the back door and had to run our friend Rusty Baxter. He's usually pretty good on the tree and runs the number, so we knew we had to match his run. Dad had a great light, and the car actually slowed down for an unknown reason. Unfortunately, the onboard data recorder activated too soon, so I lost all the data after the shift. Running the timeslip numbers, I knew it slowed in the backhalf.
For the final, we had the guy parked next to us, ironically. He's a big hitter, too - John Biagi. He'd been running 4.00's all day with great lights. We rolled some base timing into our car to try and get back to the 3.90 dial. Dad had his worse light of the day, but so did John - which saved us as the car slowed to a 3.91 once again - and he broke out trying to get there after being late at the tree.
There was one crash on Friday night, when Jonathan Johnson had no parachutes and panic-braked, pitching the car sideways and into the wall head-on. He was okay.
https://photos.app.goo.gl/w6dxARR5dvf9x9Qf6
https://photos.app.goo.gl/UTFfs5aLiUzBTJ2T6
https://photos.app.goo.gl/yYhcSY5NGxtyYvwE7
https://photos.app.goo.gl/5AA7vueXsi7Aos6q6
https://photos.app.goo.gl/8FkbRRPMmZ5FZUf8A
https://photos.app.goo.gl/oBecbeLP2Y15myLZ6
https://photos.app.goo.gl/hYRHzFKFfogBqSLV8
https://photos.app.goo.gl/zXPEMVJ27oQJxZ2x8
https://photos.app.goo.gl/o9U2KmtXnk3ZBqaq6
https://photos.app.goo.gl/JS7SPzdkxH8Dkrut5
#319
#320
https://photos.app.goo.gl/FZXCknWMoEQhqQKB9
https://photos.app.goo.gl/Aq3cuPoMUrZ9Rt8o9
https://photos.app.goo.gl/QT6L3CBKAtgeRPXV8
https://photos.app.goo.gl/Ts5n8pXkQVFoSa3k8
https://photos.app.goo.gl/R9UnPtFxLHUkiVz27
https://photos.app.goo.gl/***kwYBuca9sbapNA
https://photos.app.goo.gl/vGMMnArEcVnjqF8o7
https://photos.app.goo.gl/f5eEfvXebsq9JamGA
https://photos.app.goo.gl/jAti3RL5Sp56U5Wo8
https://photos.app.goo.gl/j49Hg6uyfXsEgkmcA
https://photos.app.goo.gl/n2HywjdGzgo5wq2aA
https://photos.app.goo.gl/tFHaUACAjrAHDjYF8
https://photos.app.goo.gl/Kv7g9od3tFvV3roa8
