Starting the build process
#411
Got the engine out of the dakota and both heads off. Intakes 3 and 5 definitely failed the water test, and the runners are visibly burned where the flame front was breaking past the valve seat.
Pulled the springs off and the guides (or lack thereof) are very loose. Valves are floppy at full lift and that's likely contributing to the valve seals leaking.
Talked to 2 different machine shops and already made my mind up on which i'm using. Quote is roughly $1,000 for 16 manganese-bronze guides, 16 valve seals, 16 valve jobs (14 cleanup and 2 fix), and 2 intake valves.
Also making good progress on wiring up the new toy.
https://photos.app.goo.gl/VSKmaK6DuPZGjLJp7
https://photos.app.goo.gl/dkwF81vrtnNUxKX49
https://photos.app.goo.gl/hRZadqUXNthoBQmp9
https://photos.app.goo.gl/cJnoo929shLcMmARA
https://photos.app.goo.gl/sqeYdkK7YdHtfZP5A
https://photos.app.goo.gl/dj8uvY7MfRGM1Atz9
https://photos.app.goo.gl/QSBP9KAW62c4MQjD7
#412
Still waiting on my cylinder heads. So far no major issues found other than Eric can't believe it didn't tear up more parts running the way it was.
We've spent some time working on the new toy. Updating a 23 year old chassis is not for the faint of heart. There's definitely been some struggles along the way.
https://photos.app.goo.gl/4V96BT8d6yYvj8xE7
https://photos.app.goo.gl/yKwUkgUKpx9kXb3x8
https://photos.app.goo.gl/sp8YP3RftctRdywWA
#413
Went to a new year's nitro party and there was an orange lambo there. It's exactly the look we're going for.
Also - picked up my cylinder heads. That story will continue later.
The seat didn't have a headrest originally. Dad made one with some aluminum & integrated it to the seat, which is tailor made to the chassis.
In the middle of all the cold, he also got the quarter and back windows all taken care of with all new MarGuard Lexan. A little more tricky because the windows are flush with the body, including a recessed bevel.
It's a 2000 S-10 Pro Stock Truck.
https://photos.app.goo.gl/D9bkkPvQha48Te2S6
https://photos.app.goo.gl/YfvD8k28mPxChyAx7
https://photos.app.goo.gl/oTSEmj9Z9j5GBtmPA
https://photos.app.goo.gl/pYnGqNG8XWXKPtZM7
https://photos.app.goo.gl/YK5h569GM4LyKhUm8
https://photos.app.goo.gl/NKLUqqHYYuuBpM3q9
https://photos.app.goo.gl/ZLZJRsrc7Txb8ctY7
https://photos.app.goo.gl/nM16JECeD8NmZ6Ct7
#414
Been a minute since I updated this thread, so let me get ya'll caught up.
We've taken the S-10 out a few times. Got down to 3 cars in our first real race attempt, but the GRID ignition is not a fan of what we're trying to do. Very inconsistent. It also runs hot - PST's were intended to be towed to the lanes, make a pass, be towed back. Driving up isn't terrible. Making the pass isn't terrible. It's coming back on the return road that it builds heat fast. No real good solution there, just an inherit design that the underhood is aerodynamically sealed; Even with a big radiator fan, there's nowhere for the heat to go. Once the hood is off, it cools down fast.
Dakota has come out a couple times too. First trip out and it was dog slow. Found out the water injection is dumping way too much water. Unhooked it but no real change. Also had a huge oil leak.
Took some time to smear a bunch of permatex gray along the back of the intake manifold, replace the O-ring on the distributor shaft (FelPro 6464) along with the gasket (comes with the o-ring), and replace the trans cooler.
Went back on on Saturday, was still stuck in the 8.10's and 8.20's, about 12.40-50's in the 1/4.
Made a pulley change after going out second round of the race, tried and failed a couple experiments, then got a 12.15 out of it. Still way slow. RT's were good in race trim - .036 red, .035 green, .019 red.
0.00 sec
4.00 - 9.67 AFR @ 3071 RPM around 44 kpa on OBD2
3.70 - 9.11 AFR @ 3041 RPM around 44 kpa on OBD2
1.00 sec
4.00 - 11.59 AFR @ 3652 RPM
3.70 - 11.86 AFR @ 3918 RPM
2.00 sec
4.00 - 11.22 AFR @ 4414 RPM
3.70 - 11.27 AFR @ 4780 RPM
3.00 sec
4.00 - 10.73 AFR @ 4684 RPM
3.70 - 11.10 AFR @ 4260 RPM
4.00 sec
4.00 - 11.43 AFR @ 4192 RPM
3.70 - 11.39 AFR @ 4461 RPM
5.00 sec
4.00 - 11.25 AFR @ 4402 RPM
3.70 - 11.23 AFR @ 4676 RPM
6.00 sec
4.00 - 10.76 AFR @ 4606 RPM
3.70 - 10.98 AFR @ 4871 RPM
7.00 sec
4.00 - 10.68 AFR @ 4775 RPM
3.70 - 10.76 AFR @ 5016 RPM
8.00 sec
4.00 - 10.77 AFR @ 4932 RPM
3.70 - 10.43 AFR @ 5154 RPM
9.00 sec
4.00 - 10.59 AFR @ 5082 RPM
3.70 - 10.26 AFR @ 5298 RPM
10.00 sec
4.00 - 10.48 AFR @ 5235 RPM
3.70 - 10.11 AFR @ 5520 RPM
11.00 sec
4.00 - 10.33 AFR @ 5472 RPM
3.70 - 10.09 AFR @ 5740 RPM
12.00 sec
4.00 - 10.10 AFR @ 5666 RPM around 77 KPA on OBD2
3.70 - 10.15 AFR @ 5925 RPM around 83 KPA on OBD2
13.00 sec
4.00 - 10.13 AFR @ 5879 RPM
3.70 - 9.81 AFR @ 6112 RPM
Fuel Sync is confirmed 8-10°
Compression check passes good
1- 175
2- 180
3- 180
4- 165
5- 180
6- 170
7- 160
8- 165
Dad looked at the plugs, there's no heat or discoloration in the threads and soot on the bases. Also very little timing mark. He's thinking it needs more timing , less fuel, or both.
https://photos.app.goo.gl/dUj1n4yQjkKjk9U47
https://photos.app.goo.gl/avjaFVSNZgF2HyvM7
https://photos.app.goo.gl/fRaQbvN9XzURVdZb9
https://photos.app.goo.gl/Ttnc3ZouYj5MtsLUA
https://photos.app.goo.gl/FpsGwddve9jHLUGv8
https://photos.app.goo.gl/DtmH2sygUCs81cS5A
https://photos.app.goo.gl/iHLi6BchYgLoz5QHA
https://photos.app.goo.gl/D4eZtHimyopUYHy49
https://photos.app.goo.gl/QqMQ4uRMt1VXShgi8
0.00 sec
1.00 sec
2.00 sec
3.00 sec
4.00 sec
5.00 sec
6.00 sec
7.00 sec
8.00 sec
9.00 sec
10.00 sec
11.00 sec
12.00 sec
13.00 sec
1- 175
2- 180
3- 180
4- 165
5- 180
6- 170
7- 160
8- 165
