Starting the build process
#301
Purchased the throttle body yesterday. Also did some math.
The charge piping will be 3" aluminum.
Four 1-¾" throttle blades = 3.5 square inches
Four 1-¾"x¼" throttle shafts = 1.75 square inches
Total Flowing Surface Area = 1.75 square inches
Four 2-¼" throttle blades = 4.5 square inches
Four 2-¼"x¼" throttle shafts = 2.25 square inches
Total Flowing Surface Area = 2.25 square inches
Half a square inch doesn't seem like alot, but trying to squeeze air from a 3" pipe through an equivalently 2.25" pipe (or even 1.75") is still quite the restriction.
But with a manifold that is almost 4500 sized and needs the raised mounting surface anyways.... Why not?
Stock air hat is 3.5" tall.
New hat is 5.5" tall.
Keg is 8.25" tall
M1 is 7" tall
Stock TB is 1.5" tall
4500 TB is 2" tall
So according to that math, I should only be 1.25" taller than a stock setup. That should easily clear the stock hood I think?
Keg is 8.25" tall
M1 is 7" tall
4500 TB is 2" tall
#302
Alot of news happened today. NHRA event next weekend got cancelled. The 2 weekends after that are TBD but the prospects aren't good.
Procharger came in yesterday. Manifold got machined today.
Took a 4150 manifold and made this behemoth Accufab 4500 throttle body fit into it with some help from PDH Precision Engineering , then chipped away quite a bit of material to flow ALL the air with minimal restriction and also open up the plenum volume a bit. Still need to clean up the transition into the runners.
https://photos.app.goo.gl/tiqoof49P7yPHNks5
https://photos.app.goo.gl/iijbnj52AGdEcNtS7
https://photos.app.goo.gl/a5m3nMGekSaDKdgj7
https://photos.app.goo.gl/9vjeNeWkiLtgzCVo8
https://photos.app.goo.gl/tZm7pJF1r6ocf8zx5
https://photos.app.goo.gl/RTXJcvhdD2fwqEPH6
https://photos.app.goo.gl/8xHrgo3xK6mvB9Dc6
https://photos.app.goo.gl/dPdX9jBFnvXxDY9h8
https://photos.app.goo.gl/YyPb8hTSwDYnTASt6
https://photos.app.goo.gl/6oagJHHmxQNzyVFg7
https://photos.app.goo.gl/MmMPtC3pW13FBEfo6
#304
This guy is good. His dad was a machinist for years and now he's been doing it for about 10. This is an old bridgeport - probably 40 or 50 years old. No digital readout, doing everything by hand and eye.
#305
This update will comprise of two posts to split the photo count...
Got the new lifter from Bullet this week. Pulled the head off and replaced the lifter yesterday and FINALLY have 16 oiling rocker arms. What a cluster that was.
I still need to grind away alot of material on the intake manifold. The exhaust port plates also need some massaging. I also have a LOOONG shopping list.
Once the manifold has been cleaned up inside, I'll put the injectors and fuel rails on.
Setting the distributor drive gear was a little fun. It took 3 tries but I finally got it in the right place.
https://photos.app.goo.gl/Aj3vWi8FqNpMViW36
https://photos.app.goo.gl/SmaovCbr4yTfQUsF6
https://photos.app.goo.gl/q7sAsXvEX2c6ppq78
https://photos.app.goo.gl/KQGm8U1ChMLGg1eH9
https://photos.app.goo.gl/LvBVHcBf32uFfW1X9
https://photos.app.goo.gl/xgFySLFRdvUorJvh6
https://photos.app.goo.gl/69uLWo7QJxsvN49t9
https://photos.app.goo.gl/v9B3m2sQGu6VbjiT9
https://photos.app.goo.gl/p7XXrNoqn1syC4qJ9
https://photos.app.goo.gl/85Ej3Az6zj2q5Fgo9
#306
https://photos.app.goo.gl/mddXN7zwA3mnKgJi9
https://photos.app.goo.gl/D1iPCXV2Ly4nHqRAA
https://photos.app.goo.gl/qUbJzhhDp9okBpAW8
https://photos.app.goo.gl/xFJSdamiqkTS7AoC9
https://photos.app.goo.gl/jW97J4MHgdFDoLTz5
https://photos.app.goo.gl/JDRDp4B1utHeebJD6
https://photos.app.goo.gl/2zby2NgpC37TdgEP6
https://photos.app.goo.gl/hsL7A8JxfgzC96939
https://photos.app.goo.gl/sySqURPvaiCzjgMd7
https://photos.app.goo.gl/mPixYsemcz9XfkAE9
https://photos.app.goo.gl/pQoWU6avLKyM5iYK6
https://photos.app.goo.gl/AxnxmqvKWcQRmxLcA
#307
#308
There is room. Barely. I think. It's going to be very close if not interference between the cold piping and the left front tire. Have a plan B if it does go interference, but it'll be a capital B to route.
#309
Another bulky update.
1- Got the intake installed, but the end gaps are HUGE. We didn't use the kit end gaskets but probably should have... if it blows oil out the front or back, we'll know why.
2- Sorted out making the throttle body clear the fuel rails. It clears by literally gasket thickness.
3- Working on a strut from the motor mount to the blower plate.
4- I've been looking at photos of another truck with Spintechs to sort out exactly where things are going to land
https://photos.app.goo.gl/GkE45hDEBScfwygr7
https://photos.app.goo.gl/6wkzi2vQrwVAvH1A7
https://photos.app.goo.gl/ztZARbyqkRoV6Q766
https://lh3.googleusercontent.com/RB...=w1545-h869-no
https://photos.app.goo.gl/aH7ETAhk78eFgf9n9
https://photos.app.goo.gl/EJ6DhBngRUvxMRha7
https://photos.app.goo.gl/SbN3TRxJoqwpyuYn6
https://photos.app.goo.gl/PaxARPJ34uUus1Ne9
https://photos.app.goo.gl/A9HZLH2EQtrrCzxp7
https://photos.app.goo.gl/36GuyFfsPDk1P9bY9
https://photos.app.goo.gl/14JCLrZrGEp8yUHP7
https://photos.app.goo.gl/S5Fjoh2Gg9ZNXiMN6
https://photos.app.goo.gl/huQNHYR6C7ADdd83A
https://photos.app.goo.gl/pU45ck3i1tYnw6RR7
https://photos.app.goo.gl/vEcu9BSmruFmmjPs5
https://photos.app.goo.gl/3cAai3B1WcKPRWxy8
https://photos.app.goo.gl/K6Kpdje36t4W1tjJ8
https://photos.app.goo.gl/9kgvknEEHGTqYGGq5
https://photos.app.goo.gl/dUWctyZypmnF7tHs8
https://photos.app.goo.gl/tCpy6Q7sEvb1xM6D7
https://photos.app.goo.gl/AxppxKXsXKYrBGou8
https://photos.app.goo.gl/qRaeM21JyEXX6gNj8
https://photos.app.goo.gl/wQEgUxbPMaqbQV6M8
https://photos.app.goo.gl/WYcMbJqQJJ8Etd6U7
https://photos.app.goo.gl/Nd6cdpSmiinCQ1ee6
https://photos.app.goo.gl/RUr8694J6ETsdCAVA
https://photos.app.goo.gl/EnuCZsYrWtjfEtiXA
#310
More update photos. The motor mount plate is welded ridiculously on the bottom - it's not pretty, but there's alot of attachment.
https://photos.app.goo.gl/PXE56BT7onGYwHTx6
https://photos.app.goo.gl/NFVSiGwvfysbgF686
https://photos.app.goo.gl/93zSAtmDQ9b59sbp7
https://photos.app.goo.gl/RuPxn4ejy2Ukqei99
https://photos.app.goo.gl/W6iys2aPUtcaEzjCA
https://photos.app.goo.gl/7rrksQGN5WsbafW39
https://photos.app.goo.gl/PTd8pYtDnnNi4TUB6
https://photos.app.goo.gl/p71P1hwSrxiBNEzX8
https://photos.app.goo.gl/DqWsxiHoxFkDRD957
https://photos.app.goo.gl/d4VFsjxPHkTzZUaK8
https://photos.app.goo.gl/ByZnxUFMzFdBo9de8
