Engine light code p1196
Old Apr 7, 2016 | 02:06 PM
Nickjung's Avatar
Nickjung
Default Engine light code p1196
Hey guys I just got an engine light code 2 weeks before I had to get emmission test. The code is p1196. Indicating bank 2 sensor 1 is not working properly. I swapped out the sensor for a new one. Driving the truck for weeks code still there. Any ideas as to what else it might be??
2001 Dodge Dakota Sport. 4.7L
Old Apr 7, 2016 | 03:07 PM
00DakDan's Avatar
00DakDan
Section Moderator
P1196 2/1 O2 sensor slow during catalyst monitor
What brand O2 did you put in? If it was a Bosch, replace it. Use NTK or Denso.
Old Apr 7, 2016 | 04:55 PM
Nickjung's Avatar
Nickjung
I did buy denso. Like I said I have been driving it for 2 months since I replaced it and still engine light. Any other ideas?
Old Apr 7, 2016 | 05:23 PM
00DakDan's Avatar
00DakDan
Section Moderator
It can happen if the mixture is too lean.
Is there any sign of a leak at the exhaust manifold?
How's the fuel pressure?
Watching the fuel trim with a scanner can help pinpoint the cause.
