02 dakota dash lights go out
Old Sep 15, 2016 | 06:47 PM
brett.samsel's Avatar
brett.samsel
Default 02 dakota dash lights go out
hellow please help my dash lights go out when high beams are turned on. the dash lights are on and work when turned on and normal lowbeam headlights are on, but when i turn my highs on the whole dash cluster and the cluster for my ac ***** turn off. I looked at all my fuses they are fine. happened about 2 months before i replaced my headlights and added a light bar they were not a cause of this problem please help me out i already called a "certified dodge mechchanic" but they all said they had never heard of anything like this happening.
Old Sep 16, 2016 | 06:48 PM
98DAKAZ's Avatar
98DAKAZ
Well if it started after you installed the lights you wired something wrong.
Old Sep 24, 2016 | 01:02 AM
brett.samsel
Nothing was wired wrong the headlights wiring was not changed and the light bar had a wiring harness I know how to wire a simple circuit I'm a certified electrician
Old Sep 24, 2016 | 09:32 AM
00DakDan's Avatar
00DakDan
Section Moderator
How did you add the light bars - where did you get power for them? Did you use a relay to drive them or just tap off the headlight feed.
Old Sep 26, 2016 | 01:49 AM
brett.samsel
Wiring harness came with a relay and fuse in line with the circuit the dash lights only cut out when I turn my high beams on and all of this happened before I added the bar and the new lights about 2 months before
Old Sep 26, 2016 | 08:50 PM
00DakDan's Avatar
00DakDan
Section Moderator
What wiring harness? Where are you tapping power?
