2000 dakota SLT 4.7 PCM swapping issue
Old Oct 19, 2016 | 04:43 AM
Vagary Huang's Avatar
Vagary Huang
Default 2000 dakota SLT 4.7 PCM swapping issue
hey guys
because it stalls randomly when driving
I just bought the new pcm for my dakota
from ebay thecompany called "flagship one inc."
I put my vin number whit the order
and the item delivered very fast
(My location is Taiwan)
I plugged the pcm, it stars for 2 sec then die at first time
then ... it didn't start anyway.
I swap the old one, it works normally
does anyone know what's the problem might be?
the vin# not programmed? mileage not matched?
international shipping costs money, and when thing go wrong just frustrated
can any one help?
and maybe other better pcm companies recommend
thanks
working on the return and refund right now
Old Oct 20, 2016 | 08:53 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum.
Sounds like the new PCM has security enabled on it. You can't disable it.
Old Oct 20, 2016 | 09:59 PM
Vagary Huang
Thank you
is that the vin# unmatched to cause the car wont start?
Old Oct 20, 2016 | 10:44 PM
magnethead's Avatar
magnethead
No, you usually have to specify on the order form if your truck has security or not, so the feature can be programmed into the PCM or removed as needed. It sounds like you have a non-security truck and were sent a security PCM.
Old Oct 21, 2016 | 07:47 AM
Vagary Huang
very helpful ! I will check this with the dealer
is that the "trim" staff ?
I've read some articles , people were talking about
so the pcm company can program this (disable it)
is that mileage really matter or not?
vin# must be right ?! other wise . . . . ?
thank you
Old Oct 21, 2016 | 01:41 PM
00DakDan's Avatar
00DakDan
Section Moderator
The way it usually works is that you provide the PCM company with your VIN and mileage.
They look up the options that the truck originally came with and program it - security enabled or not.
They also program the VIN and mileage.
Mileage won't really matter. It's stored in more than one location.
Old Oct 24, 2016 | 02:04 AM
Vagary Huang
So How do I know my truck has security or not
It has a remote control
Or is shows somewhere?
Thank you
Old Oct 26, 2016 | 12:37 PM
00DakDan's Avatar
00DakDan
Section Moderator
Pull up a build sheet. You can get it via this link:
https://dodgeforum.com/forum/2nd-gen...ur-dakota.html
Old Oct 26, 2016 | 09:00 PM
Vagary Huang
cool
I just go through the list
there is nothing about security
only the "keyless entry" confused me
is the security would put the "security" on list
or I should looking for other Key-words
thanks
Old Oct 26, 2016 | 10:27 PM
magnethead's Avatar
magnethead
Is your key skinny and black or thick and gray/greenish color?
