2002 Dak Interior Lights Oddity
Interior lights work fine with the exception of doors open, any door.
But, if I move the dimmer switch to top notch, then back to rest, the lights will come on with the door. Also, as I noticed this pattern, I believe 2nd notch no longer turns on interior lights unless I go top notch, rest, then to 2nd notch and lights come on.
Windows, locks, keyless, fogs, dash lights, all work fine.
Only thing else I can think of that doesnt work is the power mirror on driver side. All other controls on the panel works.
My symptoms dont match that of a failing CTM.
Thoughts???
Thoughts???
check your door latches. sounds like it thinks a door is stuck open and is shutting down your interior lights to prevent draining battery. Or maybe a door switch(es) is stuck with the door closed.
top notch should be interior plus cargo light. Second notch should be interior on/override. Anything else should be dash dimmer and lights with doors. Bottom notch should be interior off and minimum cluster brightness.
I can turn the wheel all the way up (interior lights on) and then back to normal (not override, but interior lights now off. Then lights work perfectly when I open the doors.
Also, new headlight switch, same result.
Also just realized the chime doesnt work either. And not just door (the cluster indicates door ajar btw) but for anything.
Trending Topics
