Coolant issue/ question
Old 01-08-2017, 09:12 PM
hidden1's Avatar
hidden1
hidden1 is offline
SCT?
I'll have to see why it's coming on at start up .
Other scanner in enhanced mode did speak of Coolant temp circuit having errors(no codes) so I'll look at that an retest including relay an breakers.
Thanks
That's 1 of 8 error messages ​​​​​​on the ECT circuit in enhanced mode. No DTCs
Old 01-09-2017, 04:40 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Check the coolant temp sensor wires they may have a brake in them causing the intermittent problem My wires had that problem had to fix the wires.
They usually get a brake at the sensor connector
Old 01-09-2017, 07:12 PM
hidden1's Avatar
hidden1
hidden1 is offline
I tested the wires to CTS an got 5.1 or 5.2--normal is 5
The ground seemed ok on continuity test to large harness at fuse/relay box.
​​​​​​After restart I had CEL an saw code p0118.
--is this because of reading of 5.1 or 5.2 an not 5 volt?
Or from all the testing of wiring?
I reset restart engine
No code so far
I will double check harness again .
Also saw how fan motor is on drivebelt an blowing a high amount on engine at start up..
Any info is appreciated
Old 01-09-2017, 07:56 PM
magnethead's Avatar
magnethead
magnethead is offline
the circuit-high code is from having the sensor unplugged with the key on. Unhook the battery to reset the PCM, or just clear the code in your scanner tool. 5.2 volts is okay, there's usually a 10% tolerance on signal lines. What voltage are you getting from the signal wire?
Old 01-09-2017, 08:10 PM
hidden1's Avatar
hidden1
hidden1 is offline
At the connector going to sensor 5.2..
Old 01-10-2017, 08:41 PM
magnethead's Avatar
magnethead
Is it only a 2 wire sensor? It should be a 3 wire I thought. I could be wrong. I know the IAT is a 2 wire.
Old 01-11-2017, 08:50 AM
hidden1's Avatar
hidden1
hidden1 is offline
Yes mine are both 2 wire.
I'm guessing the wire to temp guage in cluster is coming from pcm .Ill look at wiring diagtam.
Temp reads in run mode an idle highest is 192 an averaging 188 but guage stays at 33 % which is odd.
Old 01-11-2017, 07:08 PM
magnethead's Avatar
magnethead
no it's not. the gauge is a ranging type, as are all of the gauges except tach and speedometer (which are somewhat slow and inaccurate at times). I forget the ranges and what positions the water temp is though. I ignore it and only use the OBDII display
Old 01-11-2017, 09:08 PM
hidden1's Avatar
hidden1
hidden1 is offline
No it's a 2 wire .What else would I need to test ?
Old 01-11-2017, 09:17 PM
magnethead's Avatar
magnethead
If it's a 2 wire, and you're getting 5 volts across it, i don't think that is right. You should have more like 2.5 volts across it, if it's the kind of sensor I think it is.
If you have a multi-meter, unplug the coolant sensor with the engine cold, and take a resistance reading across the sensor. I'm just going to throw a guess out: 600 ohms cold. Plug it back in, let the engine warm up (ideally, let thermostat open). Unplug sensor and re-test. It should either be in the thousands of ohms range, or down around 100 ohms.
Theory being that it should move a very significant amount of ohms with temperature change. I dont know which direction.
